need quick and easy answers about ebay headers
Old 07-27-2010 | 08:52 PM
YodiBrodi's Avatar
Default need quick and easy answers about ebay headers
its about the obx style headers,
http://cgi.ebay.com/ebaymotors/CHEVR...Q5fAccessories
simple, are O2S extensions needed?
is there any difference in headers for 4x4 and 2wd trucks?
what size band clamps for the y-pipe connections? 3"?
Old 07-27-2010 | 09:23 PM
jpodell's Avatar
No o2 extensions are needed. Don't know about 2wd and 4wd fitment. I believe that I used 2.5" band clamps. Be sure they are lap joint style. This thread may help too.
https://www.performancetrucks.net/fo...light=eBay+obx
Old 07-27-2010 | 09:49 PM
YodiBrodi's Avatar
saw in a post where the y-pipe is 2.5" so now i have a clamp size. last thing to know, are 4x4 headers and y the same as 2wd headers and y? i'll order them tonight if there's not one.
Old 07-27-2010 | 10:04 PM
TIM Z's Avatar
11 sec. Truck Mod
Those are the headers i have. Very high quality, nicely built and fit perfect, easy install. Best value/ deal on headers period .
But they seem to be a perfect fit on the 99-02 trucks, and hit or miss with tweaking needed on the 03 up trucks, Why i dont know.
Old 07-27-2010 | 10:09 PM
Suddog's Avatar
They are the same. I asked the same questions. They are Bad *** for the price. Get some DEI 1200* spark plug protective boots for atleast three of the spark plug wires. Drivers side last two and passenger front spark plug wires come way to close to the headers for comfort. I rigged up the drivers side spark plug wires with zip ties to keep them away until I can make a permanent clamp and boots.
No o2 extensions needed. I needed to clearance a body bolt under the drivers floor board (have no idea why the bolt is that long to begin with). The system will also bolt directly to the factory exhaust. I did it until I can get it to the exhaust shop after the cam install. One note if you plan on installing yourself...heat the hell out of the manifold bolts where they connect to the Y pipe. They are a B@tch to get out if you dont heat them (damn near glowing red.) Be careful near drivers side as the fuel lines run on the frame.
I got fed up with the drivers side and just cut the Y pipe.
Money well spent. I live on Guam and they only charged me $80 in FEDEX shipping.
Old 07-27-2010 | 10:15 PM
YodiBrodi's Avatar
thanks a lot, everything i need to know. thanks for the heads up on 3 sleeves, i had 2 ready to order from summit. yeehaw, i'm going to have headers!
ARC
57
02-21-2022 10:54 AM
Zizzle
10-19-2017 08:44 PM
GMCtrk
12-18-2015 04:47 PM
Three6GMC
08-28-2015 07:56 AM
350SS
07-11-2015 12:34 PM
Quick Reply: need quick and easy answers about ebay headers
