Need a quiet muffler
Old 03-11-2012, 04:42 PM
Silverado53's Avatar
Any longer case straight thru style muffler like Magnaflow or Borla will work well. I would look for around 22-24 inches.
Old 03-11-2012, 05:07 PM
CC05's Avatar
Originally Posted by TX Tahoe Z71
I have the 22" case magnaflow with a 12" by 7" round magnaflow in front and it's pretty quiet. Has a slight rumble to it outside, but nothing inside. No drone or hum.
This is probably going to be your best option. Silverado53 just mentioned it also, so I figured I'd chime in and say that I'd go with something along these lines.
Old 03-11-2012, 05:30 PM
gonzo 6.2's Avatar
Id like to see someone use the flo pro 8880
FLO~PRO - Heavy Duty Specs
done several of these,best quiet power,chambered so has a slight flowmaster tin sound,no drone 1700rpm LS Drone is a downer for me
not sure If i used the 8880,it was a couple of different ones all good
Big oval baby http://www.flopro.com/bigoval.html
Old 03-12-2012, 09:52 PM
low2001gmc's Avatar
Magnaflow 3.5 22 long case on my 6.0 with dual 3s, no cats, y into 3.5 muffler and no tailpipe.....perfect, not loud, no drone, quiet at highway speeds, some roar at wide open throttle......perfect.......
Old 03-14-2012, 09:20 PM
Turbosixx's Avatar
The super turbo is making the exhaust very tolerable. I went with it because it's the only muffler close to the size magnaflow that was on there. Has a deep smooth sound with no rasp.
Can you guys post part numbers of the 22" case magnaflow?
Old 03-14-2012, 09:43 PM
13 Second Truck Club
A Low Dime's Avatar
Are you running a tailpipe or is it dumped?
Old 03-15-2012, 06:06 AM
Turbosixx's Avatar
Tailpipe, it's the 3" magnaflow exhaust. Being a RCSB, it doesn't have much room to add a big muffler. I'll try to take a video of it this evening and post it here.
Old 03-15-2012, 07:10 PM
Turbosixx's Avatar
Quick video. I like the sound.
http://www.youtube.com/watch?v=agdQ5...e_gdata_player
Old 03-22-2012, 01:53 AM
CAGRacing's Avatar
How about we trade y pipes
I have a high flow on road pipe made by GM
It has 2 cats and came on my truck from the factory
Its real nice
I run the factory y pipe and no muffler with no turn down under the bed and it's far from bad. The different firing order really tamed the sound on these motors.
Old 03-27-2012, 09:14 AM
slowfive0's Avatar
https://www.performancetrucks.net/fo...fflers-496693/
Quick Reply: Need a quiet muffler
