Need some advice on a combo
Old 02-16-2010, 08:17 PM
bwooten492's Avatar
Default Need some advice on a combo
I have a buddy who I am trying to help put a good combo together. He has a 02 ecsb with a 5.3 thats on its last leg. He is thinking LQ4 now and from what ive heard, the stock 5.3 heads should be pretty good on it once ported. That leads to a cam, what is a good cam for that setup that is possible to use a stock stall? This is his DD and he doesnt want some big sloppy stall in it.
Also, what extra little odds and ends are needed to make it all fit together? Thanks alot.
Old 02-17-2010, 05:58 PM
SnakeOiler's Avatar
Originally Posted by bwooten492
... He has a 02 ecsb with a 5.3 thats on its last leg.
Why is that? Was it not well maintained?
If you're gonna get an LQ4, use the LQ4 heads.
Old 02-17-2010, 11:47 PM
BigHate's Avatar
if the lq4 came with the 317 heads i would re-use those
Old 02-18-2010, 01:16 AM
PT's Slowest Truck
budhayes3's Avatar
Be sure that the 6.0 he gets is from an 01+ or will not be a direct swap to a 60E due to the longer crank flange that was originally only mated to an 80E. The 99-00 LQ4's are easily identified by their iron heads and aforementioned longer crank flange.
Old 02-18-2010, 01:58 PM
bwooten492's Avatar
Its been well maintained from what I've seen, it just has 180K on the clock. Also, what is the benefit of the LQ4 heads?
Old 02-18-2010, 02:13 PM
PT's Slowest Truck
budhayes3's Avatar
They're already bolted to the engine lol.
But actually I believe that they have bigger valves than the 5.3's and flow better. IIRC, they've been described kinda like LS6 heads with bigger combustion chambers, but I'm not 100% sure so don't quote me on that. They're 317 castings, same for LQ4 and LQ9
Vortec350ss
01-12-2016 10:36 PM
bearden86
26
11-15-2015 03:58 PM
blackedoutchevy22
10-01-2015 08:07 PM
old motorhead
09-29-2015 08:22 PM
Chevy305
09-28-2015 09:21 PM
Quick Reply: Need some advice on a combo
