Need Spring Help Please??
I have a 04 Tahoe with 799's milled 30 thous running Cometic .036 headgaskets and a Comp XR259HR Cam. specs are dur @ .050 206/212 Lobe sep:112 valve lift .515/.522 I currently have the blue GM springs but need to upgrade them because A buddy is gonna give me a killer deal on a set of 1.8 Accelerated lift rockers. I was looking for a set of springs but am not to sure about what to use. I ran across some Trick Flows that I was thinking would work and wanted to get another opionion on them from someone with alot more experiance with this than me. Trying to find a spring that will work with the stock hardware also.
http://www.trickflow.com/partdetail....6&autoview=sku
Baltimore Whore
I believe that stock LS6( yellow) springs will work fine for you. PRC makes nice springs, even though the comp 918's have had issues, tons of us have had good luck with them aswell. Majority of the springs can be used with stock locks, ect
gmcyukon
10-03-2015 11:03 PM
