Need Trans cooler help Fast...
I am doing a trans cooler right now and before I cut into the lines on the truck .... which one do I cut into? the bottom I'm guessing but I want to be sure.
top one is return back to the trans
Check member "Flyer" - check his website
He posted pics of his trans cooler install.
I copied his....
cut the top one just before the rubber joint...
I copied his....
Yea .. what he said. Cut the top one before and after the rubber piece. You can use the new ends you just made open to run the coolant through the cooler.
http://bettie.homeip.net/atvpics/truck/trannycooler
MA$TER_E
09-09-2015 03:14 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
