nelson tune--loooowww idle
hey i just installed a yank tt3000, hd 2 shift kit with sonnax 4th servo and acummulator pistons, boost valve and all that good stuff along with my nelson tune (tuned for all that stuff) yesterday. everything is great except the idle. it idles at like 400-500 rpm and it stalled once. i havent drive it very much only to warm it up, but did you guys have the same problem? i had the battery idsconnected for a while so im thinking maybe it has to re-learn or something. let me know what you guys think, thanks!
You should e-mail nelson and ask what exactly the idle is at. Also, you are gonna want your idle pretty high cause of that stall converter, cause the slightest hill you will roll back, not very much pull like a stock converter. My idle is at 700 i think, and that's pretty good for my 3200 stall.
It should adjust the idle airflow, spark and fueling to get to the desired idle speed thats been set in the PCM. If it has a low idle set in the PCM, thats what its going to try for and you won't see it get much better. If it has a higher idle set, then it will start making adjustments until it gets there.
Were you running this tune before the mods, or is it fresh from nelson?
Performance Trucks Sponsor
allen
i noticed after a few key cycles it got better, its still low @ 500 rpm but its stable now, it doesnt stutter aymore, and i was on a mild incline and it didnt go backwards. it seems fine now. the only stutter i got is when i slammed the brakes to a complete stop, otherwise its fine. havent had a chance to really get on it as im breaking in the torque converter, but it picks up a lot better now. the tune is new. so far im happy with it. if i have any more issues Allen ill let you know. thanks.
