Nelson tune MPG!
Old 04-28-2004, 09:56 PM
Formerly one92rs
one03sierra's Avatar
Talking
www.nelsonperformance.com
Old 04-29-2004, 10:06 AM
Barely Boosted's Avatar
Thats always a plus increased hp and mpg who could ask for more
Old 04-29-2004, 11:33 AM
12 Second Club
O3GMC's Avatar
My mileage increased on the first tank, and that is pressing the loud pedal down quite often. Predator shows about 26-28 deg timing and pretty lean compared to before, .890 or so, which is fine by me -
Old 04-29-2004, 12:05 PM
Performance Trucks Sponsor
FarmTruc's Avatar
glad to hear it,
i see more power around 890. than over .900 so you're just about right. just based on other trucks and wide band readings when compared to a predator, you should be running about 12.9 which is perfect/safe. I like to run mine around 13.3:1, some say it's lean, but it works,
thanks,
allen
Old 04-29-2004, 12:13 PM
what a rush!
moregrip's Avatar
what does 890 mean?
is that degrees via exhaust gas temp?
Old 04-29-2004, 12:29 PM
FarmTruc's Avatar
450mv means the 02 is reporting a lean condition, 940 means there is a rich condition.
The only accurate way to measure a/f ratio is with a wide band setup. However, if you use atap and your predator alot, along with a wide band, you can get a good idea on what the a/f is by reading the 02mv.
allen
Old 04-29-2004, 12:55 PM
what a rush!
moregrip's Avatar
what does mv stand for, are we talking tempeature here?
Old 04-29-2004, 12:57 PM
12 Second Club
O3GMC's Avatar
Originally Posted by FarmTruc
glad to hear it,
thanks,
allen
I dont know much about tuning, but seems to me that at my power level, (no power adders or risk of severe detonation) - leaner is better. I'm happy with it now, but if you think I could get a bit more power out of ~13.3 then I may have you upgrade me in the future. Again, I dont know much about how too much timing or 'leaness' can affect the motor if there is no detonation, but I'd pretty much like it maxed out - at least enough for a daily driver
Someday I'll probably want to make the trip over to san antonio and get it just perfect - even tho its very good if not perfect now.
FarmTruc's Avatar
mv is milivolt, the lower the number the leaner the reading.
for a/f ratio, the lower the number the richer.
thanks,
allen
Old 04-29-2004, 12:58 PM
Hit Man X's Avatar
Millivolts.
Quick Reply: Nelson tune MPG!
