Nelson tune MPG!
12 Second Club
My mileage increased on the first tank, and that is pressing the loud pedal down quite often. Predator shows about 26-28 deg timing and pretty lean compared to before, .890 or so, which is fine by me -
Performance Trucks Sponsor
i see more power around 890. than over .900 so you're just about right. just based on other trucks and wide band readings when compared to a predator, you should be running about 12.9 which is perfect/safe. I like to run mine around 13.3:1, some say it's lean, but it works,
thanks,
allen
450mv means the 02 is reporting a lean condition, 940 means there is a rich condition.
The only accurate way to measure a/f ratio is with a wide band setup. However, if you use atap and your predator alot, along with a wide band, you can get a good idea on what the a/f is by reading the 02mv.
allen
allen
12 Second Club
Originally Posted by FarmTruc
glad to hear it,
thanks,
allen
thanks,
allen
Someday I'll probably want to make the trip over to san antonio and get it just perfect - even tho its very good if not perfect now.
