New 350
Old 03-05-2010, 04:24 PM
bluelq4's Avatar
Exclamation New 350
ok so i just got a 350 out of a 97 pick-up i just looked up the casting numbers and it says.
its a 4 bolt main GEN 1 crate motor with ZZ4 roller cam. i am currently rebuilding the heads, i am gonna port and polish them and get heavier springs.
i am gonna rebuild the motor, after it is rebuilt i will be selling it.
i will also build the motor for you if your intrested pm me.
Thanks.
Ben
Old 03-05-2010, 07:26 PM
Coban's Avatar
This is not a classifieds section.
Old 03-05-2010, 07:49 PM
YenkoST's Avatar
The '97 Truck 350 engine was a L31 with a 192/197 camshaft...far from the zz4 cam specs of 208/221. Plus the compression on the L31 is 9.4:1 to the ZZ4 of 10:1 as well as the zz4 having aluminium heads to the L31 vortec cast iron heads.
Old 03-05-2010, 08:40 PM
1Bear's Avatar
I'm with you, but if someone was to just look up the casting number, than indeed the same block casting was probably used for both.
hodge9386
10-25-2015 01:26 PM
wickedRCSB
10-10-2015 09:29 PM
gmcyukon
10-03-2015 11:03 PM
ice17
09-22-2015 05:18 PM
cousblake11
09-09-2015 06:52 PM
Quick Reply: New 350
