new 6.0 swap. down the drain
Old 07-29-2004, 07:42 PM
Ryan23silverado's Avatar
Oh ya, melting a plug makes the ground strap open in gap size. (right?)
If it closed like that on its own...check for piston clearance
Old 07-29-2004, 08:27 PM
single digit dreamer
parish8's Avatar
i have been told detonation can push the ground like that. number 7 is always the first to go, is it really running fine with just a plug change? i would expect a broken piston.
could you hear any detonation?
Old 07-29-2004, 09:14 PM
2003blue5.7's Avatar
what is the best software for loging?
Old 07-29-2004, 09:24 PM
11 Second Club
I would warm up the truck and fill that cylinder with air see if you hear air in the oil pan. If you do there is something wrong with the piston or rings.
Old 07-29-2004, 09:49 PM
Gordy M's Avatar
Ease software is the best and most full featured, ELive is good, HPTunes is good and Autotap is fair.
Old 07-29-2004, 09:58 PM
do you have ease? Do you think I could check yours out?
Old 07-29-2004, 10:00 PM
parish8's Avatar
i think you will get the most support around here with efilive.
i had a copy of ease about 1.5years ago. it was barely better than atap back then. they probably have something better now.
Old 07-29-2004, 10:11 PM
i use autotap, but i would go with efilive if you don't have a logging program yet (efilive takes many more readings per log than autotap). OR if you need a tuning program AND a logging program i would check out hptuners
Old 07-29-2004, 10:13 PM
bigguy75inches's Avatar
i heard no detonation, and the truck seems to run fine now
Old 07-29-2004, 10:57 PM
Cuz I AM a BADMOFO
BADMOFO's Avatar
What kind of RPM were you turning the motor to when it happened?
Quick Reply: new 6.0 swap. down the drain
