new best gtech and motor goes BOOM
Originally Posted by whitt1
I have a block with crank and pistons sitting in my shop that's not being used,I need a set of valve covers oil pan and assorted parts maybe we can work some kind of trade.May you won't need to run the 4.8.
Originally Posted by BigTex
LEAN SPIKE:
On the wet kit, the nitrous is under 1000+psi, while the fuel is only at 60 psi max. When you first hit it, the nitrous will fill the lines faster, and you'll be lean until the fuel catches up.
Sorry about the motor.
Sorry about the motor man. Did your last truck get a lean spike at all?
Was it Colonel that said if you lock the converter after the 1-2 shift that your times would get worse?
Originally Posted by Flyer
That sux Parish ... on the bright side ... the 409 can be fast tracked now.
LOL @ Fast4.8
Parish ... do you have to rely on this truck as your daily driver? Just curious ... I know I couldn't live without my truck for long as it's the only thing in my driveway!
