new best gtech and motor goes BOOM
Old 01-18-2004, 07:36 PM
single digit dreamer
parish8's Avatar
Originally Posted by whitt1
I have a block with crank and pistons sitting in my shop that's not being used,I need a set of valve covers oil pan and assorted parts maybe we can work some kind of trade.May you won't need to run the 4.8.
sending you a PM
Old 01-18-2004, 07:37 PM
parish8's Avatar
it was just a 125shot, that 150 had alot of kick, kind of too much for just messing around
Old 01-18-2004, 07:43 PM
BigTex's Avatar
LEAN SPIKE:
On the wet kit, the nitrous is under 1000+psi, while the fuel is only at 60 psi max. When you first hit it, the nitrous will fill the lines faster, and you'll be lean until the fuel catches up.
Sorry about the motor.
Old 01-18-2004, 07:47 PM
parish8's Avatar
Originally Posted by BigTex
LEAN SPIKE:
yes, that part i understand. the lean spike i see lasts for about 1 sec. the dyno operator said it was much longer than he usualy saw. seems to long to me and i always see full 8deg of knock the entire time it is lean, then it starts to decline the rest of the run.
Old 01-18-2004, 08:03 PM
Black Blown 02's Avatar
Sorry about the motor man. Did your last truck get a lean spike at all?
Was it Colonel that said if you lock the converter after the 1-2 shift that your times would get worse?
Old 01-18-2004, 08:49 PM
Flyer's Avatar
That sux Parish ... on the bright side ... the 409 can be fast tracked now.
Old 01-18-2004, 08:57 PM
parish8's Avatar
it could be if i had any money, i spent more than i should have on that turbo kit. looks like whitt is going to set me up with the parts i need to get a 6.0 back in there , as long as i have the motor out i can get that stall set up corectly.
Old 01-18-2004, 09:44 PM
blownerator
BlownChevy's Avatar
its a sad day @ LS1 Tech
Old 01-18-2004, 10:17 PM
GREGGO's Avatar
Damn... sorry to hear it. You need to change your user title to exploding engine director.
Old 01-19-2004, 12:01 AM
Flyer's Avatar
LOL @ Fast4.8
Parish ... do you have to rely on this truck as your daily driver? Just curious ... I know I couldn't live without my truck for long as it's the only thing in my driveway!
Quick Reply: new best gtech and motor goes BOOM
