New Cam, Modified Exhaust
#21
If you plan on going to a larger stall, i personally would say go bigger than the 216/222.
I have a 214/222 with a TB stall, stalls 2600-2800, and in the few days I've had the new cam in, I already feel like I should have gone a little bigger on the cam
#22
I would go with vinci trucker cam 216/224 .551/.551 on 115lsa. I have the 210/218 .584/.584 116lsa in my 5.3L and it is awesome with the stock stall, so much low end tq and screams to 6300rpms. With the 6.0 you can get away with a slightly larger cam than the 212/218 and still keep the low end power due to the larger bore.
#23
https://www.performancetrucks.net/fo...-458842/page2/
Great dyno info here, look a dyno on post #12 compares a 5.3L with the 212/218 vs Lq9 with 216/224 massive amounts of tq. Makes 60ftlb more at 2500rpm than the 5.3L so I would think with around 300ftlb of tq at the wheels around 2500rpms would be plenty to prevent it from running like a dog with the stock stall.
Of course I think a 3000-3200 stall would be perfect match up, but I think you will be happy with the stock stall for a while to get around to buying/installing the new stall.
Your truck sounds good by the way
![Cheers!!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_cheers.gif)
#24
New tune for cam silverado - YouTube
Heres my truck with the 210/218. It's a dog from a dig with my 275/55/20's and highway 3.42s, but it's a beast from 20-30 rolls and once it hits 4500rpms its like a little 50 shot just kicked in.
#25
Your truck sounds good by the way![Cheers!!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_cheers.gif)
![peanut hump](https://www.performancetrucks.net/forums/images/smilies/other_mr_peanutHumps.gif)
#26
You will probably need ported heads and maybe nnbs/Lsxrt intake manifold to reach 400. Your 4L80e, 4.10s, 14 bolt and big tires are going have more drive train loss compared to a 4L60e with 10 bolt and 4.10s.
Its hard to put a number on it b/c dynos are different, but I would think around 350-360 hp with 380-390 tq. A set of ported heads would net you 30ish and intake 20ish
#27
#28
IMO I wouldn't do the L92 heads, they flow really awesome stock and are a little to much for the 6.0. You will lose some low end power with them, and have to change the intake manifold to square port.
The best set up would probably be a set of texas speed stage 2 or 3 Ls6 heads with a LSXRT intake manifold, but that would run you close to 3K and that would almost buy a used supercharger.
The stock truck intake is by far the best for low end power, most after market intakes only shine past 4500 rpms but give off some down low. The lsxrt intake is the only one that doesn't give off and low end power and gives 20-25rwhp gains 4500+ rpms
Aluminum intakes can get heat soaked and the only aluminum intake most people run is Holley Hi Ram for turbo aps
#29
I would just change the cam, lifters, gaskets, timing chain, oil pump, etc. Have your heads milled or pick up a set of 243s to bump compression up even more and see how you like it. If you want more then it would probably be wiser to start looking at boost rather than build an expensive n/a motor that has to sacrifice dd habits.
#30
![Guns](https://www.performancetrucks.net/forums/images/smilies2/guns.gif)
Mind, my current heads are 317s, what is the actual difference power/performance wise? I know, I could easily Google this, but I would rather ask straight up and get good feedback.
