New Comp Truck Cams?
Old 12-02-2005, 11:01 PM
  #21
Mr. Sandog's Avatar
Originally Posted by 99Silver5.3
Holy crap. Those are little vagina cams.
Nothing wrong with little vaginas.
Old 04-01-2007, 11:00 PM
  #22
ricoc's Avatar
Thought I'ld revieve this. Anyboby got times with these?
Little vagina=shorter times
Old 04-01-2007, 11:23 PM
  #23
Tribe Shaman
PappyDan's Avatar
not too sure if any one is selling them.
the first set of cams for the gen 3 offer more.
found only one on summits site.
http://store.summitracing.com/partde...1&autoview=sku
this cam looks like the 02 ls6 but on an lsa of 115 where the 02 is 117.5
Old 04-02-2007, 07:48 PM
  #24
ricoc's Avatar
I got this recomend lately from COMP CAMS. maybe I should tell them 5.3, stock heads and intake, 2100kg, 26" tires
Cam Spec Card Inquiry
PART NO. 54-450-11
01 INTAKE MASTER 3750R
02 EXHAUST MASTER 3751R
03 ENGINE GM G3 XFI 260 HR15
04 GRIND NUMBER GM G3 XFI 260 HR15
INT EXH
05 HYDRAULIC Y/N YES 14 DUR @.050 206 212
INTAKE EXHAUST 15 LOBE LIFT .3020 .3060
06 VALVE ADJUSTMENT HYD HYD 16 ROCKER RATIO 1.70 1.70
07 MAX GROSS VALVE LIFT .513 .520
08 DUR @ .006 TAPPET LIFT 260 266 17 LOBE SEPARATI 115.0
18 ADVANCE 4
09 VALVE TIMING OPEN CLOSE 19 VALVE SPRINGS 26915-16
@ .050 10 INT 8- 34
11 EXH 45 13- DATE SETUP 07/13/2005
12 THESE SPECS ARE FOR CAM(S) INSTALLED
@ 111.0 INTAKE CENTERLINE
Comp Cams wrote:
> <http://www.CompCams.com>
> CAMSHAFT RECOMMENDATION REQUEST CONFIRMATION: 2/21/2007 / 1:10:23 AM
> _____
> VEHICLE INFORMATION
> Make: GMC Model: 2wd rg cab short box Year: 1999
> Must Pass Emission Standards?
> Vehicle Weight: 4000 Axle Ratio: 3.42
> Transmission Type: automatic Tire Height: 28 inch
> Torque Converter Stall Speed: 2800
> _____
> COMPUTER CONTROLLED VEHICLES
> Vehicle Computer Type? Chip
> Speed Density Sensor: Dont Know
> Mass Air Sensor: Yes
> _____
> ENGINE INFORMATION
> Engine Block Type: GM
> Engine Size: 5.3 How Many Cylinders: 8
> Bore: 3.779 Stroke: 3.662 Compression Ratio: 9.49
> Piston Type: eutectic cast al Connecting Rod Type: hot-forged
> steel alloy
> Intake Manifold Type: stock truck
> Cylinder Head(s) Year: 1999 LM7 Head Part Number: 12559862
> Head Runner Volume: 200/70 Ported Heads: no
> Intake Valve Size: 2.00 Exhaust Valve Size:
> Rocker Arm Type: Stock Rocker Arm Ratio: 1.7
> Exhaust Header(s): No
> Exhaust Type:
> TunedSingle
> Exhaust Pipe Size: dual 2.5"
> RPM Range: 3000 to 6500
> Nitrous Oxide: No
> _____
> FUEL DELIVERY
> Fuel Type: gasoline Fuel Octane Rating: 91
> Carburetor: No Carburetor Size: polished throttle body
> Port Injection: Yes
> Electronic Fuel Injection: Yes Oversize Injectors: No
> _____
> AIR DELIVERY
> Air Filter: Performance
> Ram Air: No
> Turbocharger: No Supercharger: No
> _____
> APPLICATION SPECIFICS
> How Will This Engine Be Used?
> Street Strip
> Class: na
> _____
> What Type Of Cam Do You Want?
> Hydraulic Roller
> _____
> What Type Camshaft Are You Currently Using?
> Brand: stock
> Part Number: 12560966
> Specs:
> _____
> Considering The Current Performance Of Your Vehicle, Do You Want:
> More Torque? No
> More RPM? Yes
> Is Idling Speed Important? No
> _____
> User Comments:
> Engine is stock LM7. Cast iron manifolds 2.5" outlets into 3.5"x18"
> collector looking for cam,valve springs,pushrods
Last edited by BigTex; 06-12-2007 at 07:03 PM. Reason: Removed your address and phone number
Old 04-02-2007, 08:07 PM
  #25
speedy02's Avatar
Awww, baby cams. There so cute!
Old 06-12-2007, 11:15 AM
  #26
Mark Johnson's Avatar
Dumb question for y'all- at what lift do you encounter Piston to Valve contact? With anything over .500 and some more duration, don't ya hafta go to screw in studs.............
Old 06-12-2007, 06:37 PM
  #27
dirt track racer 81's Avatar
hmmm im running a .597 lift cam with stock rockers and bolts..no problem..along with every one else on here with big cams..you dont get P-V problems untill mid .6xx lift..the lsx motors are way different from the old school motors
Old 06-12-2007, 08:54 PM
  #28
Tahoe6.0's Avatar
I installed the middle one in my truck last night 208 212. Low end seems better than 218 218 that I had in. Took me 4.5 hrs to install it up and running this time. Getting better all the time on cam swaps. Going back to the dyno and test it out soon. will let you guys know.
Old 06-12-2007, 09:41 PM
  #29
yurs78's Avatar
How much power did it put down with the old cam? How low in the rpms did you start the dyno pull at, 2500? I just wanted to know because I've been torn for some time between something like the one you just put in or something like the trucker cam 216/224. I'd like to know how much is gained/lost on the low end and the high end. Thanks for your help, please keep us posted.
Old 06-14-2007, 12:44 PM
  #30
Yeah- I'm interested as well........
wrb002
08-31-2015 12:00 PM
projectnightcrawler
07-19-2015 11:30 PM
black6spdz
07-16-2015 01:32 AM
4B11T
07-13-2015 03:48 PM
07NBSChevy
20
07-08-2015 07:27 PM
Quick Reply: New Comp Truck Cams?
