new dyno numbers. woohoo
Old 04-13-2005, 09:52 AM
  #71
Cuz I AM a BADMOFO
BADMOFO's Avatar
That's awesome. But I too, like Bigtex, am impressed by something else. A guy puts down a 1000rwtq with a small block gas motor and another guy is impressed by the shutter speed of a camera!
Maybe BigTex should change his name to BigTech. j/k
Again, on those numbers, good luck at the track.
Old 04-13-2005, 10:13 AM
  #72
MOOBIES Moderator
Scream's Avatar
Congrats Jim! Please get some tires and put a cage in that thing. Do you even have a driveshaft hoop? If you plan on running at the track any, you're going to have to address the safety issues, especially if you plan to run 9's.
Old 04-13-2005, 10:32 AM
  #73
OBXMarine's Avatar
Simply Awesome!!!
When you say this:
Originally Posted by parish8
one last thing to mention was i forgot to take it out of 4wd. the tcase was locked in 4hi so the front shaft was spining the whole time along with the front carier and part of one axle. that was probably not a safe thing and robed some hp too.
You were on a 2wd Dyno right?
Old 04-13-2005, 11:45 AM
  #74
zippy's Avatar
tires would be nice, but there is no reason to be spinning the tires that fast. that truck will likely never cross the traps at 160mph so why spin them up there. after the turbo put some more gear in there and you might get a bit more use of third gear at the track.
Old 04-13-2005, 11:59 AM
  #75
agreif's Avatar
Holy hell Jim, I just saw this thread. I'm speechless here.
Old 04-13-2005, 12:28 PM
  #76
Yelo's Avatar
Good lord......I'm speechless Jim....
Old 04-13-2005, 03:58 PM
  #77
single digit dreamer
parish8's Avatar
any tire i go with will be shorter and i will eventualy pick up some speed so i think the gearing will be fine.
safety stuff is in the works along with some stronger driveline parts.
i had the tcase in 4wd , forgot to pull it out. the tcase, front shaft and front diff were all going 150mph. the one axle was not spining so the other axle(part of it anyways) was going 300mph. the front end has a disconect setup on one axle and it was disconected. stupid mistake and could have been ugly on the dyno.
Old 04-13-2005, 04:04 PM
  #78
Frank02L's Avatar
Great numbers! Thanks alot, now I'm putting my brand new T76 in the trash!
Old 04-13-2005, 04:38 PM
  #79
Green Thunder's Avatar
Yeah cuz 760+ hp and 1000 Rwtq isnt enough
Old 04-13-2005, 04:42 PM
  #80
parish8's Avatar
those numbers were with a 100shot. boost only was around 640/800. from what i understand on a smaller motor the hp would likly go up some and the tq would probably come down. i have a lot of driveline losses.
Quick Reply: new dyno numbers. woohoo
