New Dyno #'s with small pulley and Nelson tune.
Old 07-14-2004 | 12:07 PM
O3GMC's Avatar
12 Second Club
I've read multiple places that you should gain about 20hp with every 1psi of boost.....I would agree with GREGGO....you should be in the 375 range
what spark plugs do you use?
Old 07-14-2004 | 05:30 PM
vortec327's Avatar
I have heard the same exact thing, if you up 3 psi that's at least 60 fly wheel hp. then 20% loss is 48 rear wheel hp. So i wouldl say at least 40 hp rear wheel minium.
Old 07-14-2004 | 05:37 PM
greentahoe's Avatar
When was the first dyno run done?? Were there temp differences?? Did you have the bigger rims then??? You said that they didnt have a scanner, I think you may have some timing being pulled. With that much boost you are either feeling the effects of high ambient temps and/ or timing being pulled for whatever reason. I would definately get some logs when you can.
Old 07-14-2004 | 07:39 PM
parish8's Avatar
single digit dreamer
i am with the other guys, those number dont mean much without a scan tool log to go with it. there is probably an obvious problem.
Old 07-14-2004 | 07:44 PM
I think 40rwhp is still a little up there, personally. I think the limitation may be the exhaust. A L/T header and free flow exhaust will make a pretty big difference.
Old 07-15-2004 | 07:56 AM
gearheads78's Avatar
What should I get for data software. I want to get something that will work on our 98 TA also. I have always had carbed hotrods but seems like its time to make the next step learning on my EFI cars.
Old 07-15-2004 | 08:13 AM
the harder you turn the blower, the less efficient it gets. plain and simple. it isnt a linear result, esp when you are pushing over 6 psi. the heat created = loss of power. 1 psi = 20 rwhp. then i guess you should just pulley it up to turn 10 more psi. get 200 extra rwhp....
saying that, still need to get some scan results, they will tell everything.
Vindii
04-14-2016 09:06 AM
Go5.3tt06
09-12-2015 09:29 AM
Layn22s
08-31-2015 03:43 PM
dselby25
08-24-2015 07:26 PM
01sierraon22s
07-08-2015 11:26 AM
Quick Reply: New Dyno #'s with small pulley and Nelson tune.
