New exhaust setup
Originally Posted by dropkick13
sound clip would be great, idle, light acceleration, cruise, heavy acceleration...whatever you wanna get!
I wont need extra pipe if i put the turn down directly after the muffler...but this might drone too much. o well...sounds like most people 'guess and test' with their exhaust set ups...guess ill have to do the same
I can tell you the JBA exhaust is a very mellow one. I'm assuming it would be similar to a Magnaflow-muffler-only system, but I couldn't say for sure. It's pretty quiet if you don't get on it, like normal daily driving. The only time the drone is bad (in a Yukon) is when I'm cruising about 70. Drone gets pretty bad then...
ah well, with the subs and amp i have, drone really won't be heard haha
how expensive is piping anyway? i have to weld the muffler in because its 3" in/out and stock piping is 2.75" so i cant just play around with muffler placement as easy.
if piping is realtively expensive than ill probably just put the new muffler welded right where the stocker is followed by a turndown right off the muffler and pray it doesnt drone too bad. if piping is not expensive than ill go ahead and move the muffler back as far away from the cab as possible (would i weld extra piping to the stock piping or just replace it all?)
Restricted User
I have dual 3 inch ys from my headers and going to convert to true dual now.
this muffler magnaflow sells is a dual 3 inch in/out with internal x pipe and flows great.
http://cgi.ebay.com/ebaymotors/ws/eB...m=270038556329
right now i have a single in/single out magnaflow but there are duals coming into it that is y'd to the single inlet thats why im getting rid of the muffler.
here is a clip and yes its loud. with the bigger magnaflow above it will give you the sound your looking for and will not resonate in the cab or drone
ps- the muffler i have now is a 5x8x18 3 inch offset entry/3 inch center exit
HERE Is the new muffler
Originally Posted by mabutler
I tried to get some sound clips and you couldn't even hear it in the cab so I guess its not that bad. I don't think piping is that expensive. They just used scrap for mine so it was free. A while back I think I bough a 5' piece for like $40. If you don't care how it looks underneath then I would just weld it to the stock pipe. You might want to just put the muffler on and see how it sounds then you could either put the turn down on or run it back further if its too loud.
anyways, tubing is cheap
btw when asking for exhaust piping/tubing make sure you know what to get. measure the diameter of the ports you're wanting to connect. if it's 3" inside diameter, you need some 3" tubing to go into that. if it's 3" outside diameter, you need some 3" pipe to fit over that. pipe = ID tube = OD
just a little info
also, if you're needing to weld the 2.75" to the 3", you can get expanded adapters to fit it properly... otherwise you could just weld the gap, 1/8" isn't much, 1/4" is stretching it and that's a lotta weld to plug.
im just going to put the magnaflow 4x9x18 right where the stocker is, and dump it immediately after. if it drones too much, ill buy a few more feet of pipe, cut off the muffler somewhere in the stock pipe, weld in the extension, and push the muffler as far back as possible. I'll let you all know how it wounds in a few weeks (not going to be home for a while). yea i would like to hear those pacesetters...i should be getting those eventually. (are you with cats or without?)
I ordered mine from AJ-USA...
http://www.ajusa.com/cgi-bin/jba/sta...3fe9fe989f5dc9
I believe it was around 300 bucks, give or take a little. Full 3" aluminized catback. The fit was PERFECT, very nicely built unit. It's got some type of coating over the pipe (silver), not sure what it is. Could be paint, but is holding up really well.
