New mototron 60 lb. injectors
It looks like mototron has set of 60 lb. injectors that will fit our truck intakes(shorter injector). I think the only thing you have to do is convert over to the LS1 stall clip.
Today I ordered the mototron long body L107's 60lb. the short bodys are about 5/8 of a inch shorter than a stock injector dont think they will work too short where o rings seal to intake and fuel rail. Long bodys need 5/8 spacers and longer bolts to lift fuel rails easier to raise rail then to drop but might be wrong.Also got injector clips 8 with pins for around $13.00 msd #2400.
