New SES Codes!!!! Yippeeee!
Old 06-25-2005, 09:28 PM
single digit dreamer
parish8's Avatar
broken number 7 pistions on boosted aplications is prety common too. if you had a tuning issue that let it run lean and it was detonating then you may have messed up the engine.
Old 06-25-2005, 09:32 PM
Destroyer of Transmissions
1SlowHoe's Avatar
After reading this I smiled. My wife looked at me disgusted and asked how I could be happy about a blown engine. Ummm, 6.0L. I guess I better figure this problem out quick cause if it's not torn up yet I don't wanna give it the chance.
Old 06-26-2005, 08:58 AM
Banned
litreddevil's Avatar
If You Think It Is An Inj. Problem Then Take #1 Inj. And Put It On #7.then If You Still Have The Miss Disconnect The Exhaust And See If It Goes Away If It The Converters It May Be To Late .
Old 06-26-2005, 10:55 AM
sd155racer's Avatar
firing order
Old 06-26-2005, 12:24 PM
gonzo 6.2's Avatar
Originally Posted by sd155racer
18436572
firing order
WRONG
here's the firing order
18726543
Old 06-26-2005, 12:26 PM
1SlowHoe's Avatar
Earlier somebody said #7 was the LAST cylinder to get fuel??
Old 06-26-2005, 12:34 PM
KySilverado's Avatar
If I understand it correctly, it is the last in line of the fuel system. If you run out of fuel volume it will be the first to go lean. Also any contaminants that may make it to the motor would probably wind up here.
Old 06-26-2005, 07:00 PM
11 Second Club
Texas Terminator's Avatar
Boost-- 3.4" pulley, about 6-7 #'s
Injectors--Stock for a flex fuel truck, unknown flow rate, maybe 30#'s?
How hard do I drive-- Is there any other way?
I have a guy who's going to look at it tomorrow. He is looking up bulletins right now. Anybody know the # bulletin that references this issue?
smells like a piston/ring BBQ to me. check for excessive crankcase pressure too. before my old 4.8 took a crap, it blew the dipstick out and progressed from there.
Old 06-26-2005, 07:51 PM
Banned
Have You At Least Took The Front O2 Sensors Out To Take Back Pressure Off The Motor. Have You Check The Plug.
What Dose It Look Like?
Compression What Is It?(compare It To The Rest On The Left Bank)
Move The #7 Injector To The #1and #1 To #7 See What That Does.
Old 06-27-2005, 12:30 PM
looks like sd155racer thought gm left the firing order alone.
GM did a 43-72 swap for the gen-3(LSx) engines. 18436572-18726543
I hear it smooths the torque curve???
Quick Reply: New SES Codes!!!! Yippeeee!
