New truck, Whipplecharged, help me get it running right
Well guys I picked up a 99 1500 Sierra last week. It's kinda a bastard of a truck as it has a 2500 Chevy frame underneath it, but should work well for pulling my Trans Am around. Regardless, the truck has a Whipplecharged 6.0 and is not running like it should.
From my limited amount of research, I think I've pinpointed the problem. It seems that the secondary injectors provided are not kicking in, causing a lean condition, causing the bypass valve to open which is only allowing the 4-5 psi I am seeing. From what I have seen on here, the secondary injectors provided with the kit are not too popular on here, and I'm not particularly fond of the idea either, so I've been looking into injectors.
What injectors would you guys reccommend, 42s or 60s? How much boost should this blower be making? I assume 7-8 psi, but that's just an assumption. How much boost can a 6.0 take? I'd like to pulley down to about 10 psi, but can't find anyone that sells pulleys for these things.
Also, does anyone have any reccommendations on rebuild for the Whipple blowers? I've talked to the High Speed Lab, and they seem pretty good, but I'd like to know if any other options are out there.
11 Second Hall Moniter
At 10 psi, the 42# injectors should work just fine. If you want some room to grow, the 60# injectors might be better. I agree with ditching the Whipple electronics. You might look into HPTuners or EFILive, either one will really help you with diagnosing troubles in addition to adjusting your tune.
You need to know the pulley size to know the boost. Chances are it is a stock pulley which is good for 5psi. From my experience when I completely removed the Whipple and sold it. My truck ran better and faster. Whipples produce a ton of heat. They just are not worth it. You want a real supercharger buy a magnacharger. Another option is to add some form of chemical intercooling. Alky control kit or a small nitrous shot. I do recommend taking the whipple completely off the truck and see how it drives. It might surprise you.
My blower is not intercooled. I haven't seen a ton a positive feedback on this blower but it is what on the truck and it is what I'm going to work with. Buying a completely different kit is just too much money for a daily driver/tow pig. I'd like to possibly use some meth injection in the future. I just feel that if I get rid of the Whippletronics, get a good fuel system to accompany the blower, and get it tuned right, it will run just fine. I'll shoot Whippled2dr a pm today.
2nd fastest 5.3 ECSB
I would like to see someone use the Whipple computer and injectors to spray methanol with. Of course, after you add the 42s and get a tune. It would involve adding a pump, a regulator, a tank, and re-piping the auxiliary injectors. Also you would have to remove the wire from the bypass solenoid so that the computer can't bypass the blower. Either way you go, you will have to do that anyway.
Mine made 6 psi as set up from Whipple when I had a stock 6 liter..
