Newbie Nitrous Questions??
Old 08-24-2004 | 09:18 PM
WillPewter2000's Avatar
Default Newbie Nitrous Questions??
I have a 2000 silverado 5.3 with a vortech cold air intake and dual flowmaster exhaust. Tonight I purchased a used zex nitrous oxide system. It currently has the 125 jet in it. I'm needing to know if I need to change my spark plugs and if so what size also is there anything else that I need to install with this kit???
thanks for all help
William
Old 08-24-2004 | 10:56 PM
one03sierra's Avatar
Formerly one92rs
Talking
i am running the nx kit with a 150 shot. i switched to ngk tr6 plugs.
Old 08-25-2004 | 07:13 AM
is that the only modification that I need to worry about? thanks again william
Old 08-25-2004 | 09:08 AM
tooquick2beslo's Avatar
Is this on stock fuel pump and stock injectors ?
I have a 125 shot and Im a little scared to bump up the shot...
How many times have you sprayed it ?
Old 08-25-2004 | 06:31 PM
StupidFast's Avatar
I don't know much about Zex. I would change the plugs to TR6s. Stock pump is fine but, I would change the filter just because. Remember not to squeeze it at too low RPM, above 2500.
Have fun.
Old 08-25-2004 | 07:59 PM
Tr6's. "Don't spray on the platinum plugs." was advice I believed.
Old 08-25-2004 | 09:35 PM
where did everyone run their lines?? I plan on taking out my jack box and mounting the bottle behind the drivers seat. Also I need to run the white wire from my zex box to the tps wire can anyone tell me which wire this is? thanks for all the help William and one more did you all just tap your jet into the plastic housing before the throttle body or did you put it in the rubber hose after the air box i believe it will have to go to the plastic but im not sure
Old 08-25-2004 | 10:42 PM
Formerly one92rs
Talking
well i started haing idle issues with the tr6's. removed them and in stalled tr55 v-groove plugs and she is running much better. right now it is on the stock fuel pump. hopefully in the next few days i will get my fuel ceel,pump, and reg in to run it stand alone.
blownss27
08-14-2020 08:27 AM
06 4.8
09-11-2015 10:36 AM
bisqikss
09-08-2015 03:35 AM
iregret
09-07-2015 01:20 PM
06murder
09-04-2015 03:54 PM
Quick Reply: Newbie Nitrous Questions??
