Newbie at tuning??? Silverado SS
I am a newbie at tuning so I was wondering what it does exactly and what the side affects are to it. I here alot of people have problems after a tune. Codes, check engine light, engine acts up... Why the problems?? Is it really worth the cost?? Why doesnt the vehicle come stock with the best performance possible already??
Thanks guys!!!!
Thanks guys!!!!
Thanks guys!!!!
Thanks guys!!!!
yeah it is. It is the most noticable gain you can feel for the price. I have the nelson tune and it works real good. check out the website www.nelsonperformance.com . I would go with a custom tune instead of a programmer. They give you more power.
Banned
1 Post
All For Fed Regulation Is One Reason Your Tune Is Like It Is Also Emmissions That Have To Pass Fed Test.if You Get A Code After A Tune Is Because They Didn't Remove Someting Out That Should Be Removed.their Is Hundreds Of Codes And At Times The Tuner May Forget Something.and Just Like Arreguy01 Said They Change A/f And Timeing Remove Rear O2 Sensor Missfires Take Out Knock Sensors,take Out Evap Codes What Every You Want,put Shift Points Were Every You Want Them Also
5.3lSilverado
25
08-29-2016 12:48 AM
mzoomora
01-03-2016 07:06 AM
oharajo
07-18-2015 09:24 PM
