next step for more power
Old 07-18-2011, 07:46 PM
  #31
14psisupra's Avatar
yep.taking all i can get, researching some low boost turbo setups now maybe be an option. i would have no plans of ever boosting it very high. something in the 7-8 range should be a major upgrade
Old 07-20-2011, 05:48 AM
  #32
Amedee's Avatar
In that case some 317's would work well with a turbo setup.
Old 07-20-2011, 02:55 PM
  #33
14psisupra's Avatar
Looks like im gonna stay N/A. Thinking adding both some 243s milled .30 and 7.35 pushrods and the tsp220. Does all this sound right? Anyone with this same setup have some dyno numbers?
Old 07-20-2011, 03:25 PM
  #34
13 Second Truck Club
grey matter 04's Avatar
sounds like a good setup!
I would mill more off the heads to gain more compression
Should make in the neighborhood of 340 like most of the 220 setups depending on the dyno
Old 07-20-2011, 06:57 PM
  #35
14psisupra's Avatar
will i notice any drivability differences with milling more? say i do between .30-.40 .what head gasket thickness would i run. stock?
Old 07-20-2011, 08:45 PM
  #36
stock head gaskets will do just fine
the added compression will help lowend torque
i would go 40 for a lil bump in compression
Milling 30 off will only get you back to stock compression because of the big combustion chamber of the 243s
706 has a 61cc chamber ...243 has a 64 cc chamber ....
Old 07-24-2011, 07:59 PM
  #37
14psisupra's Avatar
ok got a few parts together,
8.1 injectors
pac 1218 springs
243 heads. any downside to milling .040 on a daily driver? will i notice drive ability differences as opposed to .035
arp head bolts
and looking to pick up a tsp220
with this setup i still have a few questions. what thickness headgasket should i use and what length push rods? 7.375 or 7.350
ARC
57
02-21-2022 10:54 AM
silverstreak07
06-28-2016 06:29 PM
thunder550
10-08-2015 04:53 PM
livefast1
09-25-2015 07:31 PM
fastjweb
08-15-2015 10:47 AM
Quick Reply: next step for more power
