nitrous install complete
After 2 weeks of agervation (burned up my purge and lost a jet) I finally finished installing the nx stage 1 kit and tested it today with 100 shot and wow I do think Im getting some what some refer to as detonation. It sounds like a crackling noise kinda like rice krispies under my hood when Im WOT with nitrous. Is that detonation and if so I have a vhp tuner and I can only knock out timing in increments of 10 degrees will that be too much timing to take out?
Im using denso iridiums IT16 which i think is stock specs. I tried changing my timing with the tuner but I think it didnt take. The option for timing set comes up first then the choices for performance level comes up a few choices after that. I think when I select highperformance it disregards my timing retard of 10 degrees Ill have to call vhp and ask.
Is it a wet or a dry kit?? You need to get some colder plugs and at least borrow a scan tool until you get your tune worked out. Detonation will quickly put you in the market for some new pistons...... maybe even a new motor.
put in the colder plugs before your next WOT...on an NX system, take 3 deg per 100 shot on the timing...you can also give it a SMALL amount of extra fuel...but dont continue to WOT with detonation
10 Second Club
Originally Posted by mrr23
it's 10% not 10 degrees. and no it does not disregard the -10% you would select with the hiperf/stock cam selection. once you select your choices, it sets the program to what you want to do. why do you think it did not take? you have my number. give me a call. robert.
13 Second Truck Club
Location: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
1 Post
That crackling/rice krispies noise is detonation. Change your plugs to TR6's if you haven't already and take the timing down a bit and/or put in higher octane gas. You can also jet the nitrous rich.
