Nitrous vs Cam heads
I am thinking about buying a NX dry shot, was planning on getting a bigger cam
and better heads but I use my truck as a daily driver and would like to keep gas mileage. What kinds of HP gains can I run safely with nitrous on stock fuel system? Only programmer I have is a Hypertech PIII
Running on a tight budget.
May spray 2-3 times a month.
Any suggestions on what kind of Dry system and where to purchase?
Thank you
Thank you
I would just go cam and NX wetkit. It is much easier on your fuel system and the gains are much better.
Heads are too expensive for the little gain they provide unless you have a hookup. $1700+ for a 20-25hp gain is kinda weak IMO. I been there done that.
Nah, not on my truck.
Just seen too many dynos on F-bodies where they dyno 390-400 with just a cam then with heads they rarely do over 420 unless they do some really trick stuff or use better than your typical $1700 heads.
If you wanted to go cheaper you might look into a set of milled 6.0L heads. They flow better than the LS1 heads and if you mill em you could see some nice gains for under $1k I would think.
Probably near stock I would think. If you drop the LS1 or 6.0L heads on our trucks it would lower the compression. At least I know this is true of the LS1 heads. So by milling them you should end up near stock or maybe close to 10.0:1 unless you milled them heavily.
Am I way off in this?
Originally Posted by 900Z1
No Suggestions on NX Dry?
The main problem you wil run into is your stock injectors are gonna be too small if you do heads/cam AND nitrous. I bet your duty cycle is gonna go through the roof.
With just a cam I am already running out of injector.
slowlsx
08-10-2015 05:33 PM
lsxperformance
08-02-2015 10:08 AM
