Nitrous...what gauges to run????
Old 12-22-2004, 12:54 PM
Slammed01's Avatar
Default Nitrous...what gauges to run????
So I ordered my NX 125 shot kit. I need to know what aguges i should be running with everything.
I already have the tranny temp, got that with the Caddy cluster.
Suggestions?
Old 12-22-2004, 12:59 PM
Deckhand's Avatar
I like the way autometer cobalt gauges look.
I would suggest a nitrous pressure and fuel pressure. They are a little expensive though.
Old 12-22-2004, 02:20 PM
Nitrous, fuel, EGT and oil pressure are good ones to have. You just have to decide how many gauges you want and can accomidate.
Old 12-22-2004, 03:41 PM
TigerFan187's Avatar
I just got the DynoTune digital n20 pressure gauge and the Dynotune digital A/F ratio gauge(reads in millivolts) put in last week. The A/F gauge came with a purchase I did on eBay. I know its not 100% accurate reading off of o2 sensor but it will work untill I do the wideband one day. They are really nice gauges. Let me know if you want some pics!
Old 12-22-2004, 06:23 PM
KySilverado's Avatar
Fuel Pressure, Nitrous pressure, Air Fuel Mixture
Old 12-22-2004, 06:31 PM
13 Second Truck Club
Location: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Old 12-22-2004, 07:25 PM
Oh boy here we go again with the whole A/F thing.
Let's make it perfectly clear that it's supposed to be a 5V wideband or UEGO type A/F setup. 1V narrowband setups need not apply.
NOTE: No disrespect to your post KySilverado, just clarifying your post a bit.
Old 12-22-2004, 07:51 PM
None taken. But I have to question the absolute need for wide band monitoring of a nitrous aided pull. Narrow band will still indicate an extreme lean condition and rather quickly I suspect. I'll take that over nothing when playing with nitrous. Fine tuning of WOT fueling is another subject
Old 12-22-2004, 08:00 PM
GoldenVelvet's Avatar
Air Fuel is the most important and though I think wide band is the way to go a narrow band is better then spraying blind
Old 12-22-2004, 08:36 PM
nitrous pressure gauge & a vacuum gauge...the nitrous gauge is for knowin the bottle pressure (nice to have a constant)...vacuum gauge will tell you when things are going bad or if theyve gone bad
Quick Reply: Nitrous...what gauges to run????
