Well I have no trims, B1 O2 sensor is reading 447 flat. Bought a new sensor from PepBoys and just replaced it, still no B1 O2 reading, just flat 447. Burned my freaking arm good in the process ....I checked the fuses, no luck.
Are you absolutely sure that it is pluged into the correct plug, meaning you might have mistakenly plugged it into the B1S2 plug... It would make sense cause you just had your tranny out a little while ago when this problem arose???
it's a distinct possibility...I have a ramp but barely fit under this fugger...I need a lift or at least a jack and jack stands. Are the plugs the same?
on my truck they are, i am not sure about yours... The reason I mentioned it because one of my friends on here (Colton) did the exact same thing.... Stranger things have happened...
