No Power?? Sorry this is a little long
#22
Originally Posted by CHEVY6000VHO
Are you sure that your valve springs have enough seat pressure?
It's a possibility that your valve springs are flatening out after 5,000 RPM's.
Just a suggestion or thought.
Jim
Jim
#23
Originally Posted by rosscob
I am not sure of that, but I did install Comp 918 springs. Is there a way to check the seat pressure on the vehicle?
Your IAT sensor should be moved to after the S/C. That should help drastically!
#24
Thanks you everyone for your help!
#25
I'm running around 6psi. My boost gauge is holds stead all the way thru the entire rpm range... It could be creeping...
ARC
57
02-21-2022 10:54 AM
slowlsx
08-10-2015 05:33 PM
