Noobie LQ4 build. Info/advice anyone?
Ok, going with the l92s. According to what I've found they'll raise compression to 10:1 and that is about what I'm after. Still considering the hot cam and I think this can price to be a great powerhouse! Kinds like the superchevy lq4 build only fuel injection. Those of you who read that article, do you think this build will have comparable results with efi? Anything I should alter/add?
You will have great results, but keep in mind that these runs were on an engine dyno, and not with a engine/trans/drive train combo. So the numbers will be lower if you hit a dyno later on.
Everyone will say that there are better cams out there, than the Hot Cam. You can make more power bla lba l. . . bla bla . . . The more popular cams on this site are the 220's and the 224s. They're an all around "stock head" cam, for heads that have not had any work done to them.
Most performance cams for the L92s have more seperation to take advantage of the huge intake valves.
Can anyone help me withany other items I need to have to do a LQ4 block/L92 heads/LS3 intake/FBody Accessory engine? Are there any items I need to get besides these for that setup? Any particular computer to use? Just wondering if anyone has any info on this.
BTW thanks for the much appreciated info everyone. I will do some looking on the 220s and 224s. Thanks for that! Hope it's ok to pick everyone's brain here! Hopefully once I get this project under my belt I can help somebody the same way!
So, when I change heads and intake, will I still be able to use any harness and computer, or do I have to use LS3/L92 specific harness? How does that work? Also, (I know I know newbie questions!!) On a classic truck project like this is for, what sensors are neccesary and which are optional? Just trying to see what I need to be prepared for when I get this beast together. Thanks guys!! Most helpful!
Is there any difference in the lifter valley covers from one LS?LQ to another? And does anyone know of any issues I'm going to have putting this engine on an S10 frame? I have decided (barring a good deal on used F-Body accessories) to buy the accessory drive for LS3 corvettes at Pace Performance ($770.... best NEW deal I found... anyone have any other ideas please feel free to let me know). So that is the setup LQ4 with corvette acc. drive. Anyone know of any problems I'll be looking at on an S10 frame?
Registered User
there's a few write ups on the GM high Tech, Car Craft, and super Chevy. Fly cutting the pistons is not needed unless you're going to run a big duration cam.
http://www.superchevy.com/technical/...dup/index.html
http://www.carcraft.com/projectbuild...ock/index.html
calsdad
06-14-2023 11:07 PM
jscherbs
09-30-2015 07:54 AM
