NOS Question
Guest
Posts: n/a
NOS Question
If I was to put a sneeky pete kit with about a 30 shot and also the new 05131NOS Universal V8 kit at about 125, is it possible to use the small shot for the start and switch on the 125 at the end for my 97 5.7L Vortec L31 C1500? Also, am I supposed to put the nozzles after or before the MAFSensor and the IAT sensor?
Re: NOS Question
thats exaclty what you need to do, setup the silenoids to run on a rpm window switch one with multiple settings and set the silenoids on the sneaky pete system to come on at a lower rpm and the others to kick on at higher rpm, put the nozzles after the MAF and you may be better to get a wet kit and just upgrade to 2 stage as buying 2 setups will be more expensive plus dry nos sucks!
Re: NOS Question
If you are using a "sneeky pete" on a fuel injected vehicle you need to make sure the vehicle is set-up for running rich (these were orginally intended for carbed engines) or spray in front of the MAF (The nitrous works "bottle in a bag" kit works this way and supports up to 75 HP in SOME vehicles.) Be sure to have adequate fueling when running a wet and dry kit simultaneously ... to little compensation by the MAF and things could get ugly.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">plus dry nos sucks! </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Really...how do you figure?
Re: NOS Question
I dont know something about it makes me paranoid as hell. the way you put the NOS in without any physical fuel jetting, like a wet system, Im just afraid of something going wrong with the fuel pressure or something and then boom! I like the idea of the wet NOS a lot better as long as you can control puddling.
Re: NOS Question
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">I dont know something about it makes me paranoid as hell. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">An honest answer, maybe not the best argument but honest. If you really think about it though, how much do you really know about nitrous and how the odorless tasteless gas works to make power on a molecular level? Probably not much (most poeple don't nor do they care to know) but you still [i]trust[/t] that it works right? ... You have a basic grasp of the operating principles and go with it. Often times the assumption of less widely used or less understood makes things bad...this is where a lot of the nitrous myths stem from. Realistically, you have no more control over a MAF, regulator or pump malfunction and could have the same BOOM with the wet as the could happen with the dry.
Guest
Posts: n/a
Re: NOS Question
Well I already have the "Sneeky Pete" with me and since NOS doesn't have a Specific kit for my truck yet, I see they have that universal wet kit. The kit for my 1997 chevrolet c1500 silv. 350 5.7L Vortec L31 "will come out early 2003" said NOS. I think Ill just wait or I guess I could get them to make me a custom kit by providing a TB spacer and info. Thanx All!
carid
09-10-2015 09:07 AM
