O ring Nightmare!!!!
Tin Foil Hat Wearin' Fool
Originally Posted by FarmerBeau
I found the rest of the oring chewed up in the oil filter. I was releived! And Cody, you were right!!!! Im sorry.
I figured out what i did wrong; I put the damn o ring in the pump and then stuck the tube in the pump rather than putting the o ring on the tube itself. I would recommend dropping the fuggin oil pan (completely) for anybody that hasnt done it just for safe measure to avoid the situation that i went through. I took off the pickup tube and first got the o ring adjusted, actually threading the bolt in with my hand and fine tightening with a socket, then adding the nuts to the studs on the bottom of the windage tray. Everything is good to go now and its Penut Butter Jelly Time!!!!!
I bet it is all worth it though and you will really be happy once Allen gets ahold of it.
Sexy Party Mod
Good deal. I seem to remember someone saying to put it on the pickup tube then put it in the pump.
Im excited about heading to San Antonio but i have to wait to get my gears, exhaust, tranny and verter installed. It lags soooo bad below 2 grand. IT NEEDS THE FUDDLE NOW!!! And once again, you were right, you told me so, im a phuckin idiot.
Sexy Party Mod
So you got pops to spring for the trans and verter huh?
And yes Colby, i put the o ring in the damn pump rather than it being in the tube which i should have done in the first place!
EDIT: and saved you another day and a half of wrenchin'
beau, so how much money do you get your dad to throw in for your truck with him not knowing what its going for? youre really working him over arent you...ha ha
