O2 Sensor Question
O2 Sensor Question
My truck has 45K and is almost 5 yrs old. I've read that O2 sensors usually go bad gradually, over time, and are pretty bad by 100K.
Is this generally true? My mpg is about 2 mpg less,recently,than it had been. It has no drivability issues.
I wasn't planning on changing them now.
I read that they range from .1v to .9v with .45v being optimal. They can't be checked with a digital volt meter?
PT's Slowest Truck
You could find out which wire (on each sensor) is the signal back to the PCM and backprobe it with a good digitial multimeter and make sure that it switches back and forth between .1 to .9 volts something like 8 times in 10 seconds (can't remember the exact frequency at the moment). Probably easiest to access the wires right at the PCM under the hood.
