OBX "longtubes"
#94
Originally Posted by 99Silver6.0
Sweet deal. You could always have that Y tigged up real nice!
Why did you hack off your thumb?!?!?
i dont have plugs for the 2 other bungs yet, but i kindof ghetto rigged it just so that i can drive it to work without it being too bad. took it for a test drive and i am happy for the most part, but at certain RPM's, it sounds really raspy almost like a popping maybe? and i'm not happy with that part. but i am going to wait till i get everything else fixed before i make my final judgement on them.
two more things:
what is the easy trick to the spark plug wires?
and what could cause the raspy/popping type of noise?
truck has SB intake, these headers and then 3in from the Y-pipe back with a magnaflow muffler 5x8x14 (#14219)
#95
well, after doing some searching, i think i might know what the problem is, i may have cracked a spark plug or damaged a plug wire i thought i was careful, but maybe i did hit one. so i'm going to try and swap those out in the next day or two
which spark plug/wires should i get? and where can i get the boot protectors to protect them from the headers?
-thanks
Shaun
-thanks
Shaun
#99
Originally Posted by kbracing96
For the extra O2 holes, go to the parts store and get some 14mm x 1.5mm oil drain plugs. They will screw right in.
and yes, they have that funky bend on the drivers side.
