Official NBS V6 to GENIII V8 swap Guide
#101
Yeah that is what I was fearing, the cost. A dealer is selling a 2001 chevy silverado 1500 4x4 4.8l for $4,000 but it has 200k miles on it. Should i even consider buying it and do an engine swap on it? Or what do you think?
#102
11 Second Club
No spacer is needed for 03 up. Not sure about 99-02. I did a V6 to v8 6.0L with NV 3500 about 4 years ago in a 03 RCSB 4x4. It works perfect. Best upgrade ever and it gets better fuel mileage. Used a 4.8 stick clutch and flywheel. I reused the clutch slave and throw out bearing.
#104
Registered User
I'm looking into swapping up from my 4.3 to a 4.8(not looking to race or do anything like that) would that be about the same as going to a 6.0 in regards to the work that needs to be done?, and what is the best company to buy said engine and transmission from that is turn key and reasonably priced.
#106
Man Motor club
1 Post
#107
i have a 2002 4.3 silverado and bought a 2005 5.3 vortec for it with harness, computer and transmission for it. i am not a mechanic but got a mechanic to put it in. the things that he did was put a 2002 5.3 intake to be able to use the same fuel system as the 02.Ran custom fuel lines to fit the intake. then noticed the c152 connection did not plug in directly to the truck harness. i got the end of the plug off a 2005 and looked at a schematic and found the colors being the same the only thing one wire from the 2005 was a tan being a fuel pump secondary and one wire that didnt connect was a black and white off the 02 truck being a axel switch. I used the tb of the 05 to connect the sensor then we got a fusebox for a v8 but didnt get a 05 was a 02 fusebox. Put the battery on and notice not all the gauges lite up. try to start the truck and truck didn't even start. what would you say i need to do next seems like the mechanic hit a stump not being experienced in doing this swap would u say get the 05 fusebox or use the 02 v6 fusebox. Or do i have to change out the harness for the gauges for a 05 silverado. please any advise will help thank you
#108
So what about cluster? Will speedo, tach, temp etc. Still work?
#110
So a 2002 v6 fusebox will work for the 2005 v8 motor?
As for the engine harness of the 05 i installed the module and pedal to make the truck dbw
if DBC then any harness from 99-02 , if DBW then any harness from 03-06
if you want to swap from DBC to DBW not worth it at all , if you swapen it cuz the engine is 05 swap the intake manifold and engine harness to a 2002 or older model
