Official NBS V6 to GENIII V8 swap Guide
#141
Custm2500's Rude Friend
That's your problem.
It will not work with the 03 up system for the cluster and everything else.
You will have to change the red connector to a green connector from your old harness and re use the original PCM. It will then need to be re flashed for a V8.
Or Re-pin the V6 harness by adding the injector circuits and reflash the computer for a V8
#143
Then you just need an operating system that uses a mechanical throttle body. There were some that retained the mechanical TB and I know for sure a Van would have that.
#146
OK so what exact engine mounts and frame mounts do I need? Original post is vague and my dealer is retarded and I'm close to that haha.
This is a 4.3 to 6.0 LY6...
Any help would be appreciated. Tried searching but can't find part numbers...
Truck is a 2003 2wd and engine is a 2008.
#147
Are these the 2 brackets I need?
GM 15113848 and 15113847???
edit; Ordered those above part numbers from the dealer with my discount.
#148
