Official NBS V6 to GENIII V8 swap Guide
Old 04-26-2018, 02:21 AM
  #241
Nwfjarhead's Avatar
Originally Posted by Sebastianrocha
Do i get a new fuse box or i just send my harness get made for my 99 sipberado
Cheaper to buy a 99-02 V8 harness
I’m looking to buy a 04+ harness as soon as possible.
Old 04-26-2018, 07:26 AM
  #242
Chado2448's Avatar
Anyone had issues with their tach reading wrong after a swap? Mine is 8-900 rpms off
Old 05-23-2018, 09:59 AM
  #243
Registered User
SunnyMane's Avatar
Originally Posted by Derek @ EDO
NBS V6 to V8 Swap
So basically you’re tired of going slow and want some power and obviously you want to swap out that old 4.3 for that massive V8 so let’s get to it. There are some other threads out there but they aren’t really informative because most people have a shop do the swap unlike me who did the swap myself with a few friends.
What do I need?
You need the engine of course, the motor needs to be turn-key.
turn-key means 100% ready to bolt in and fire up. It needs to look like this
Attachment 138390
Attachment 138391
It needs the wiring harness from a V8 Silverado, if you have a 99-02, get that harness if your motor is 03+ be sure to get a harness for an 03+ reason being the 99-02 models have a drive by cable throttle body and the 03+ models has the electronic throttle body.
Manifolds: the hell with manifolds get you some long tube headers and custom exhaust.
Pacesetters are great for the price. You can reuse your stock manifold bolts and gaskets off the v8 motor if your new motor came with them.
PCM- AKA the computer- The V6 PCM is the exact same externally as the V8 PCM the only difference is the tune or program that is written to the PCM. So you will need to have your V6 PCM reflashed and tuned with the V8 parameters. I would recommend Nelson Performance. Nelson Performance
Allen will send you a PCM tuned for your new motor and mods in which you have installed. The tuned PCM will also be tuned for the V6 Vin # so everything will fire up on the first try if everything is hooked up correctly. Once you receive the new PCM simply send Nelson Performance your stock V6 PCM. Nelson Performance is not the only option, there are some other options such as custom DYNO tuning or other mail order tuners. Just be sure to ask whoever does the tuning if they can indeed reflash the V6 PCM with the V8 parameters and V6 vin.
Transmission- The V6 transmission will bolt up but it will live a short life behind the new powerplant. I would recommend purchasing a built unit from a reputable Transmission shop such as FLT (Finish Line Transmissions) Finish Line Transmissions | Performance Transmissions | Torque Converters | Transmission Parts | Transmission Service
FLT builds flawless units everytime and they dyno test them before shipment. Chuck or Vince can recommend a specific model for your needs.
Note: the stock V8 unit will break just as fast so get a good built unit that will suit your needs.
Torque Converter:
A stock V8 converter will work but the whole purpose of this swap is for power right?
A torque converter alone can knock off a ½ second off of your ET.
Vigilante and Yank build good stalls, They can recommend a stall speed for your application and mods.
Flexplate- You will need a 4l60e flexplate from a V8 motor, a stock one should work fine.
Note: If you purchased a 6.0 and it has a flexplate on it already it probably will not work because the engine was most likely mated to a 4l80e transmission.
Fan shroud: you will need a v8 fan shroud if you plan on using the clutch fan, BTW now is a good time to upgrade to E-FANS!!! If you do upgrade no shroud will be necessary.
Motor mounts: unfortunately the stock mounts will not work. You will need to purchase 99-03 ½ ton frame mounts and engine mounts, you can get these at your local chevy dealer or find them from a salvage yard.
Hoses: you will need 99-03 radiator hoses- upper and lower, AC hoses, Heater hoses,
you will also need a nipple that connects to the back of the intake manifold that provides vacuum for your brake booster, the 6.0 engines power breaks use their power steering pump. you can get this from the dealer or off a 4.8,5.3 intake manifold.
Radiator: yes your stock v6 radiator will work, the only difference between the 28” v6 radiator and the 28” v8 one is one small connector that returns coolant back to the radiator from the throttle body, search TB bypass for more info. Simply install a T on the hose coming from the radiator reservoir that runs to the radiator and connect the line from the Throttle body or block (if you bypassed) to the T fitting. Be sure to use hose clamps to insure no leaks.
Air Intake: the air intake setup on the V8 engines are completely different than the v6 setup, you can purchase a stock unit or replace with an aftermarket setup. FYI you can also do a search on the board that will inform you of what you will need and where to buy specific parts to build your on Cold air setup that will compare to the best aftermarket ones.
Note: the stock box will work you just need the tube.
The stock MAF (mass air flow sensor will work as well)
Fuel Lines: The stock fuel lines will not work with the new motor, you will need
2 EAR-165056ERL -6 - 5/16 AN to tubing connectors Male end
2 EAR-165006ERL -6 - 3/8 AN to tubing connectors Male end
2 RUS-658490 1 ft sections of pre assembled 5/16 Steel braided hose with female ends
Simply attach one 5/16 to -6 tubing connector to the fuel rail on the intake manifold
Then attach the 3/8 to -6 tubing connector to the return line on the fuel rail on the manifold the above PN#’s are from Summit Racing
Cut the fuel “tubing” about 6 inches below the firewall and follow the same steps as above. Now attach the hoses to the fittings which are now on the tubing. MAKE SURE the fittings are on snug! Now when the time comes to hook up the lines simply screw on the lines to the manifold.
Note: be sure to label the lines, Fuel and return. Fuel being the larger line and the return the smaller in diameter.
Oil cooler: most 6.0’s come with a oil cooler stock from the factory, this is not needed so you can buy the block off plate that comes on the v8 engines. The oil cooler lines will connect right above the oil filter on the block. You can get this part from your local dealer for a few bucks, be sure to get the gasket as well.
Well that’s it, other than the above you just need to know how to pull a motor and how to put one back in! which can be found here. https://www.performancetrucks.net/fo...d.php?t=363112
Good luck and if you have any questions or comments about this thread Post up!
Attachment 138392
Attachment 138393
Attachment 138394
Attachment 138395
Attachment 138396
Could the my harness from my 05 v6 be used on a 4.8/5.3?
Old 05-23-2018, 10:36 AM
  #244
FFDP's Avatar
The V6 harness is missing wires to lots of things so the V8 harness is needed to connect to all the injectors, coil packs, throttle body, MAF/map etc etc.
Old 05-31-2018, 09:59 PM
  #245
BIG_D_74's Avatar
What diameter hole do I need to punch in the firewall for the DBW pedal to TAC module harness? Looks to be approximately 1-5/8" to make the factory grommet work. I feel like this has been stated earlier in the thread but I couldn't find it.
Old 06-05-2018, 03:41 PM
  #246
100% Redneck
RedXray's Avatar
Received 1,334 Likes on 794 Posts
The OP says to cut the fuel lines 6 inches below the firewall (maybe he meant cowl). This is kinda ambiguous to me. If you were cut the lines six inches below the firewall you cut off the fuel line mounting bracket that attaches to the bellhousing stud and the lines will be to short.
I set the intake with the fuel lines on the motor to see their relationship to that bellhousing stud/bracket. I think if I cut the lines just above the bracket I'll be close... thoughts?
I've got some space to get in there and cut the lines now. Doesn't hurt to have a background in body/paint/collision (retired)
Old 06-05-2018, 10:53 PM
  #247
100% Redneck
RedXray's Avatar
Did a quick test fit with the engine to see where I need to cut the fuel lines. There is a bend in the lines above the mounting bracket. I think I'll slightly straighten the bend then cut just above where the line is straight enough for the union. It looks like the evap quick connect will also fit once the line is straightened. It feels good to finally see the 6.0 between the frame rails even though its just a test fit.
Old 06-05-2018, 11:42 PM
  #248
makes children cry
_zebra's Avatar
i cut mine on one of the straight sections above the bracket. just high enough to where the braided lines ain't stretched tight.
Old 06-05-2018, 11:48 PM
  #249
100% Redneck
RedXray's Avatar
What did you use to cut the lines? I know my smallest tubing cutter will not fit between each line... cutoff wheel?
Old 06-06-2018, 08:50 AM
  #250
makes children cry
_zebra's Avatar
granted it's been 9yrs, but i think i carefully popped them out of the bracket to separate them enough because i do remember using one of those little tubing cutter wheels that you tighten & roll around it until it cuts through.
Quick Reply: Official NBS V6 to GENIII V8 swap Guide
