Official NBS V6 to GENIII V8 swap Guide
#291
Thanks, I have a feeling you are gonna be a source for alot of answers to the questions that arise as this swap gets underway.
So having not done any of this before, is swapping the ECM plug and play to original fuse box or do I need to get that from the donor vehicle too?
#292
makes children cry
the new harness will swap into the fuse block with a bolt. i had the black on in my 99 & swapped to an 01 setup & harness.
also, if you don't want to tap the water pump (if i'm seeing that picture correctly) for the TB bypass, just get a t-fitting for the small coolant line going to the top, pass side of the radiator. run the hose from the valley cover under the TB to the t & cap off the TB barbs.
#293
100% Redneck
#295
Does anybody know if the frame mounts for a 4x4 v8 Silverado are the same as a 2wd v8 Silverado on the drivers side? I used the frame mounts from a 2004 5.3 4x4 and I noticed that the frame mount from the v8 is wider than the part of the frame that the mount bolts to on the v6. Does anybody know why this is?
#296
Custm2500's Rude Friend
1. Does anybody know if the frame mounts for a 4x4 v8 Silverado are the same as a 2wd v8 Silverado on the drivers side? I used the frame mounts from a 2004 5.3 4x4 and I noticed that the frame mount from the v8 is wider than the part of the frame that the mount bolts to on the v6. 2. Does anybody know why this is?
2.Yes, the frames are physically different. See mount types in quote below.
Navi (02-01-2019)
Navi (02-01-2019)
#300
Part numbers
Looking for part numbers for the frame to mount bracket 2wd 2007 classic 4.3 to 2002 6.0 swap I ordered mounts from GM that the dealer thought was complete but didn’t include the frame to mount bracket
