Official NBS V6 to GENIII V8 swap Guide
Old 08-10-2019, 04:52 PM
  #341
makes children cry
_zebra's Avatar
but the 5.7 is a Gen 1 SBC setup just like the 4.3, whereas the 4.8, 5.3, LSX454, etc are all Gen 3 setups which are completely different.
either way, your 03 ain't an OBS truck like the video is made for; it's a NBS.
Old 08-13-2019, 12:39 AM
  #342
100% Redneck
RedXray's Avatar
Received 1,334 Likes on 794 Posts
Originally Posted by Chuy05
I found this video on youtube and arent the lines in the 5
7and 4.3s the same since they both had the same throttle body and intake design ?
Watched the video and it looks like it may work for you, If so post back to add to this thread.
Old 08-14-2019, 09:26 PM
  #343
CCollins's Avatar
I realize this is a “engine swap” post, but being that it’s exactly what I am doing I have a question.
The front suspension as stock.... did the v6 truck come with different coil spring weight than the typical v8 trucks? Mine pre swap already seems to sit a little low in the front. No complaints from me tho! Once I swap the 6.0 and all of its turbo system hardware, I’d expect it to sit even lower. My thoughts were not to do any type of drop on the front and simply remove the middle leaf on the rear to gain the desired ride height I wanted. If the spring weight/rate is much different than a v8 factory front end, will I have issues??? Goal is to have a streetable daily that’ll make occasional track passes, therefore the front suspension needs to participate in that game plan.
Any my help would be appreciated
thanks
Old 08-17-2019, 12:52 AM
  #344
100% Redneck
RedXray's Avatar
If you are running an iron block 6.0 it's around 75lbs heavier than the 4.3. If it's a LS2 aluminum 6.0 it's about the same as the 4.3 Vortec. I couldn't tell much difference in height after the swap but I'm running aftermarket 2" drop (2" spindle) front springs.
Old 09-15-2019, 09:03 PM
  #345
Chuy05's Avatar
To all of the gurus out there that have came before me.. here is the dilemma that I'm in. Any help would be greatly appreciated. I've swapped the 4.3 to the 5.3 and got it in and did wired in the engine tied it into the stock 4.3 fuse block and im not getting the engine to crank at all. Dl you guys have any ideas what it could be the starter is good and I hear my injectors but no crank to the engine.
Old 09-16-2019, 03:22 AM
  #346
Custm2500's Rude Friend
1FastBrick's Avatar
Could be a couple of things. But with out some more details It's like throwing darts blindfolded.
For starters, What year is the truck?
What do you mean "I got it wired in"? Did you use a V8 harness?
What about the PCM? Was it set up for a V8?
Old 09-16-2019, 05:41 AM
  #347
Chuy05's Avatar
Sorry about that here is the info it's a 03 Silverado I bought a wrecked 03 suburban swapped the engine put the v8 harness on it seed straight forward but now when I turn the key to the run position I hear the pump and relays then I turn it to the start position and the starter doesn't turn over. For the time being I'm using a flashed pcm out of my 82 5.3 swapped truck
Old 09-16-2019, 08:10 AM
  #348
1FastBrick's Avatar
Did you try with the 03 suburban PCM ?
What year is the 82 swap truck PCM ?
Are the grounds from the harness connected at the back of the block?
Old 09-16-2019, 08:40 AM
  #349
Chuy05's Avatar
I did try the 03 suburban pcm and no luck. that's why I pulled the one out of my 82 it's a 05 engine swap. I have 3 grounds I believe is what I counted
Old 09-16-2019, 08:45 AM
  #350
1FastBrick's Avatar
Yes 3 Ground wires.
I am not sure if there is any difference between a V6 fuse box and the V8. Did you full seat the connector and bolt it down under the fuse box?
Maybe check and make sure you didn't bend a pin. I have done that before.
Try the V8 fuse block from the suburban?
Quick Reply: Official NBS V6 to GENIII V8 swap Guide
