Official NBS V6 to GENIII V8 swap Guide
#372
The LS2 throttle body is a DBC btw and so is the 4.3. I just need to figure out the mounting solution for the cable bracket.
What are the benefits to keeping the throttle body heater line?
#373
2005 Silverado Base 2wd V6 to V8 swap question
5 speed manual NV3500, with LQ4 auto V8 harness.
1. Correct me if I'm wrong, but from what I read, the clutch pedal position wire just gets depinned from F10 in the V8 harness and repinned to F11?
2. I will take the VSS connector and Back Up Lamp switch connector off the V6 harness, but are there already wires to butt splice these to in the V8 harness? Or will I need to pin and run wires myself in order for the PCM to see this data?
I have schematics showing the path and wire colors but I assumed these two wires are in the donor auto vehicles trans harness? Am I wrong?
Pics and diagrams would be appreciated.
Thanks in advance,
LINEITUP!RACING (Fbook)
Thanks in advance,
#374
makes children cry
not 100% sure... i ended up sending my harness to CurrentPerformance, where they took all the auto stuff out before i tried installing it.
the only thing they missed was that purple clutch switch wire that's literally a jumper between two harness block pins (can't remember which offhand). just check your v6 harness; i'm pretty sure it's the same spots.
#375
Now as for the Backup Lamp Switch and where to hook that connector up into the auto harness, I'm still working on figuring that out. I know the BLS (manual) and PNP (auto) both follow same path in schematics and is Gray wire from PCM and Pink wire from fuse block to either of these switches.
And this clutch jumper thing is yet to be solved... Still hoping someone has graphic details and/or pictures for the Clutch Pedal Position (CPP) to send signal to ECM to engage starter.
#378
Custm2500's Rude Friend
The Upper plug looks like a 3 pin plug, not sure what that's for.
