Official NBS V6 to GENIII V8 swap Guide
Old 01-20-2020, 07:51 PM
  #371
makes children cry
_zebra's Avatar
so long as the avalanche was 2wd, they should work.
not 100% sure on the electrical answers, but it sounds like you've taken the right things into consideration.
most guys just bypass the throttle body heater line.
Old 01-20-2020, 08:02 PM
  #372
Registered User
drewm3094's Avatar
The LS2 throttle body is a DBC btw and so is the 4.3. I just need to figure out the mounting solution for the cable bracket.
What are the benefits to keeping the throttle body heater line?
Old 03-09-2020, 10:58 PM
  #373
ANGRYZ06's Avatar
Default 2005 Silverado Base 2wd V6 to V8 swap question
5 speed manual NV3500, with LQ4 auto V8 harness.
1. Correct me if I'm wrong, but from what I read, the clutch pedal position wire just gets depinned from F10 in the V8 harness and repinned to F11?
2. I will take the VSS connector and Back Up Lamp switch connector off the V6 harness, but are there already wires to butt splice these to in the V8 harness? Or will I need to pin and run wires myself in order for the PCM to see this data?
I have schematics showing the path and wire colors but I assumed these two wires are in the donor auto vehicles trans harness? Am I wrong?
Pics and diagrams would be appreciated.
Thanks in advance,
LINEITUP!RACING (Fbook)
Old 03-11-2020, 12:12 AM
  #374
makes children cry
_zebra's Avatar
not 100% sure... i ended up sending my harness to CurrentPerformance, where they took all the auto stuff out before i tried installing it.
the only thing they missed was that purple clutch switch wire that's literally a jumper between two harness block pins (can't remember which offhand). just check your v6 harness; i'm pretty sure it's the same spots.
Old 03-12-2020, 09:02 PM
  #375
ANGRYZ06's Avatar
So I answered one of my own questions so far. The VSS are the same color wires and same connector. The VSS on the auto harness is near the big round gray TCM transmission connector. So that one is easy.
Now as for the Backup Lamp Switch and where to hook that connector up into the auto harness, I'm still working on figuring that out. I know the BLS (manual) and PNP (auto) both follow same path in schematics and is Gray wire from PCM and Pink wire from fuse block to either of these switches.
And this clutch jumper thing is yet to be solved... Still hoping someone has graphic details and/or pictures for the Clutch Pedal Position (CPP) to send signal to ECM to engage starter.
Old 03-12-2020, 09:24 PM
  #376
ANGRYZ06's Avatar
Here are a few schematics to which I was referring..
Old 03-21-2020, 08:18 AM
  #377
ANGRYZ06's Avatar
What are these plugs for? More so the bottom 2 pin connector. It has a blue and green wire and was in the V6 harness but not the V8 harness.
Old 03-23-2020, 06:04 AM
  #378
Custm2500's Rude Friend
1FastBrick's Avatar
The Lower plug with 2 pins is for an Electric fan option for the radiator. This started in 2005. Its wired to the PCM and can removed from the V6 harness and added to the older V8 harness of you plan on adding E-fans
The Upper plug looks like a 3 pin plug, not sure what that's for.
Old 03-24-2020, 09:09 PM
  #379
zachary_mcclure's Avatar
Default Wiring harness
Are the Silverado and suburban engine harness the same?
Old 03-24-2020, 10:58 PM
  #380
100% Redneck
RedXray's Avatar
Received 1,334 Likes on 794 Posts
Yes but only between 99-02 and 03-06 years. A 2003 harness will not fit a 2001 year model. You also need to match transmissions 4L60, 4L80 and manual.
Quick Reply: Official NBS V6 to GENIII V8 swap Guide
