Official NBS V6 to GENIII V8 swap Guide
Old 03-25-2020, 06:33 AM
  #381
zachary_mcclure's Avatar
Originally Posted by RedXray
Yes but only between 99-02 and 03-06 years. A 2003 harness will not fit a 2001 year model. You also need to match transmissions 4L60, 4L80 and manual.
I bought an complete running 05 suburban dbw and gonna swap into a 03 4.3 nnbs dbc. Other than the obvious like tune, headers, fuel lines, etc... is there anything else I need. I noticed there is no hole for the dbw to come through the firewall like the suburban?
Old 03-25-2020, 01:58 PM
  #382
100% Redneck
RedXray's Avatar
Received 1,334 Likes on 794 Posts
The engine harness will work for your swap You may need 2wd or 4wd V8 engine mount brackets. You didn't post if your Silverado is 2wd or 4wd, the brackets are different between the two. I'm not sure if the brackets are the same on the SUV's and the trucks. You may find the answer in this (long) thread. The V6 brackets will not work BUT some say the Silverado V6 2wd passenger bracket will work. I replaced both with new ones so I'm not sure. After you pull the engine out of the burb you can match the brackets and part numbers with the info in this thread.
zachary_mcclure (03-25-2020)
Old 03-25-2020, 06:46 PM
  #383
Thanks I probably should of started a new thread. It’s 2wd and if I have to order mounts no problem. If I just swap everything will it run and drive or will I need to get the computer tuned for it to start.
Old 04-23-2020, 03:52 PM
  #384
Chris Williams's Avatar
I have a 2004 chevy silverado that had a v6 it didnt have a electric throttle body. i got a 5.3 out a 2002 it dont have a electric throttle body either. what harness will i need, i have the one that came with the 2002 5.3
Old 04-25-2020, 11:20 AM
  #385
sshrop's Avatar
If your planning on using the v6 PCM the 02 harness will not work as it is blue/red and your v6 pcm is blue/green. I would suggest sourcing an 03-06 harness and pin out for the IAC and TPS sensors. LT1Swap.com has a lot of info on this. Also if your considering swapping a 4l80e trans look for a 2500 or express van 6.0 harness this will have the correct plugs for the 4l80e.
RedXray (04-25-2020)
Old 04-26-2020, 09:00 PM
  #386
I have the 02 pcm with harness
Old 04-26-2020, 09:03 PM
  #387
Registered User
Kobe Norton's Avatar
So, I have a 2000 RCSB 4.3 5 speed rwd and a 2005 Crew cab 5.3 4wd auto. both running and driving, and I want to swap the 5.3 into the 2000. Beings I have everything necessary for both of them to run will I need to buy anything at all? I figured i can just replace the 4.3 mounts with the 5.3 mounts. I wondered though about the computer, can I just swap in the 5.3 ecu, pcm, etc with the engine and it will work fine? I wondered about going from auto to manual trans if some connectors on the wiring harness will be wrong. Or if I could swap the auto trans into the 2000 and just ditch the t case and keep the pickup rwd?
Old 04-26-2020, 09:09 PM
  #388
makes children cry
_zebra's Avatar
pretty much all of that's answered in this thread.
going from an 05 to a 00, you'd also have to swap the electronic gas pedal over; the 2WD & 4WD frame sides of the engine mounts are different; a 4WD transmission is a different length than a 2WD, so that's not a direct swap either.
happy reading - there's a lot to double-check & verify before you start.
Old 04-27-2020, 07:43 PM
  #389
KevinD1985's Avatar
great thread I'm slowly putting together my parts for my 2005 w/t 2wd 4.3/4l60 v8 swap.
I picked up a lq4/4l80 out of a 2004 3500 chevy express. my truck and the lq4 is drive by cable. What would be the easiest harness that would be plug and play?
Old 04-27-2020, 08:38 PM
  #390
Registered User
okay so I’ve read it all once, I’m going to reply to you, and then read again. But so far, I’m getting a driver side frame side engine mount because the donor is 4x4 and the target is 2wd. The passenger 2wd mount will work. I’m getting 2 braided lines and 4 connectors, cutting the original hardlines slightly above the bend. I’m swapping the dbw setup into the target. Electronics, has me STUMPED. it’s seeming the 05 wiring harness, pcm, ecu, etc. is NOT going to work in my 2000 even though it is following its home engine. Am I missing something? I need to go through again like I said, I passed by some posts about modifying the wiring harness from an auto truck to work with manual trans, I will re read them. I vaguely remember the connections to the fuse box in my 00 are not going to line up with the 05 harness. Can I swap In the 05 fuse box? Or do I just comtinue to modify the harness for my box? I feel I understand everything but the steps needed for the wiring harness to work, do I need to find a different harness? I know I’ll need the 05 pcm re tuned and vats deleted. Like I said I’m just confused on what needs to be done to match these 4x4 auto 05 electronics to my 2000 2wd manual.
Quick Reply: Official NBS V6 to GENIII V8 swap Guide
