Official NBS V6 to GENIII V8 swap Guide
Old 04-27-2020, 10:03 PM
  #391
makes children cry
_zebra's Avatar
that sounds right on the frame mounts & fuel lines.
i'm not 100% sure on making the 05 harness work in a 2000 because most folks advise just finding an older harness (and v8 cable throttle body [the v6 cable will work with it]... or pull from one of the few 99-02 with a DBW setup [i think some of the SUVs with stabilitrac]). whichever harness you run will need the matching PCM.
if it comes down to it, Current Performance did my harness work (from an 01 auto into a 99 stick) & did a good job. they ended up taking a while but made up for it. sorry i wasn't much help there.
just remember the fuse block needs the jumper wire for the clutch position switch or the starter won't get juice... can't remember the pin numbers of the black block, but it's in my build thread. not sure if the whole fuse blocks themselves can swap...
Old 04-27-2020, 10:19 PM
  #392
100% Redneck
RedXray's Avatar
Received 1,334 Likes on 794 Posts
Originally Posted by KevinD1985
great thread I'm slowly putting together my parts for my 2005 w/t 2wd 4.3/4l60 v8 swap.
I picked up a lq4/4l80 out of a 2004 3500 chevy express. my truck and the lq4 is drive by cable. What would be the easiest harness that would be plug and play?
The Express Vans engine harness will work perfect with that setup as both are DBC and the 4L80 transmission connectors are on that van harness.
KevinD1985 (04-28-2020)
Old 04-28-2020, 08:31 AM
  #393
Registered User
Kobe Norton's Avatar
Okay, so then will a 99-02 wiring harness work with the 05 engine? Will I need an intoaje or just the throttle body?
Old 04-28-2020, 11:03 AM
  #394
Registered User
I have a quick question for clarification, I have a 2000 2wd v6, from my understanding the passenger mount will work fine. The driver side I’m looking at buying 15113848 correct? This is the mount for a 2wd frame. I’m only confused because the engine is coming out of a 4x4 pickup, so I’m assuming the engine mount is the same and I just need the 2wd frame side mount?
Old 04-28-2020, 11:05 AM
  #395
KevinD1985's Avatar
Would it plug right into my v6 pcm or would I have to repin some things? I'm open to grabbing a standalone or grabbing the v8 pcm. Thanks just starting to learn about the wiring side.
thanks
Old 04-28-2020, 05:26 PM
  #396
100% Redneck
RedXray's Avatar
thanks
Yes it will plug right into the 2005 V6 PCM if it's not the "black box" PCM. If I remember correctly only the 99-00 V6's were black box PCM's. You'll need a V8 base tune file installed as it will not run on the V6 tune. If the engine is not heavily modified a mail order tune would get you up and going. Richard (Atomic) a sponsor here can probably fix you up with any level of tune you need.
Atomic Performance
Black Box PCM
Old 04-28-2020, 05:53 PM
  #397
KevinD1985's Avatar
Here the pcm thats in the truck right now with the v6
Atomic Performance
Black Box PCM
Old 04-28-2020, 09:18 PM
  #398
makes children cry
_zebra's Avatar
yeah, that silver PCM works with Gen3 engines.
Old 04-28-2020, 10:45 PM
  #399
100% Redneck
RedXray's Avatar
That's the 1 megabyte P59 PCM and will work with your trucks v8 swap and also with the Express van's engine harness. It needs to be flashed to a V8 tune. I have read that if the operating systems (v6 to v8) match it still takes 4 credits ($50 each). If you can get your hands on that vans V8 PCM it may be cheaper and easier. The Dealership may be able to flash the V6's PCM to a V8. Someone with more knowledge with segment swaps could tell you more. HP Tuners forum would be the best place to ask.
Old 05-01-2020, 09:50 PM
  #400
Chris Williams's Avatar
Default I got a 2002 5.3 harness and ecm
I got a 2002 5.3 engine, harness and computer, put it all in had to use v6 fuse box. but my problem is the c152 connector does not match the the 04 connector that runs down the frame
Quick Reply: Official NBS V6 to GENIII V8 swap Guide
