Official NBS V6 to GENIII V8 swap Guide
Old 05-15-2020, 02:43 PM
  #411
makes children cry
_zebra's Avatar
01 tahoe harness on my 99.
for the most part, 99-02 all work together (with minor differences) & 03-07 all work together (with minor differences).
the two groups have major differences between them.
RedXray (05-15-2020)
Old 05-18-2020, 06:47 PM
  #412
Chris Williams's Avatar
Default I got a 2003 Chevy Silverado 5.3 harness For my 04
There are 2 little connects that don't plug up. Then there's 2 other a little down the harness that I can't find where they go. Then the fuel pump and gas gauge not working
Last edited by Chris Williams; 05-18-2020 at 06:54 PM. Reason: Little 2 connectors are under fuse box
Old 05-18-2020, 06:56 PM
  #413
Default The 2 little connectors are under fuse box
Then the other 2 idk where they go
Old 05-18-2020, 07:04 PM
  #414
100% Redneck
RedXray's Avatar
Received 1,334 Likes on 794 Posts
There is a odd plug called an EVO connector that goes to the back of some power steering pumps. Most don't use this connector, if it's like this and you have no connector on the steering pump let it ride. As for the other connectors a photo might help.
Old 05-18-2020, 09:23 PM
  #415
Default Ill get pics tomorrow
not that connectit
Old 05-19-2020, 05:51 PM
  #416
Default I think I got a 4x4 harness
I think I got a 4x4 harness. It's not going to work on a 2wd?
Old 05-19-2020, 10:30 PM
  #417
Default Do you still have
Doing a 2000 GMC 4.3 to 6.0 (LQ9) swap and hit a snag. The donor engine, wiring harness and ECM (12589463) came out of a 2005 Escalade. Just received an e-mail from Brendan Patten from LS1Swap and he confirmed the 2005 harness will not work with my 2000 fuse block.
If anyone is in the reverse situation and in need of a UNCUT 2003 - 2006 harness and ECU and wanting to swap (or has a 00-02 harness for sale) hit my PM. This is the only issue holding me from completing the swap. I'll list the harness and ECM in the classified section if someone is in need. I also have a used but clean DBW throttle body I won't be able to use.
​​​​do you still have that harness
Old 05-19-2020, 10:54 PM
  #418
100% Redneck
RedXray's Avatar
Sorry no I sold it a while back.
Old 05-25-2020, 07:56 PM
  #419
Default I finally got the right harness
I finally got the right harness. But the full pump is not working. They I turn the key to the start position and it will turn over, the i turn off and turn back to start position then it will not turn over have to turn off for a 30 seconds to a minute then it will turn over again. Please i really need so advice. My trucks a 04 and I got the engine harness off a 04. Feel free to message me on Facebook at Chris Williams i live in Louisiana
Old 06-22-2020, 11:33 AM
  #420
Chrisrobin29's Avatar
What's up guys i did my swap about a month ago , and it went fine except im having problems i think my motor is sitting wrong i got a v8 frame mount for coil springs like my truck but im not sure on if i put in a v8 mount on the passenger side. It seems like my motors to far over and hitting my steering shaft.
Quick Reply: Official NBS V6 to GENIII V8 swap Guide
