Official NBS V6 to GENIII V8 swap Guide
Old 09-12-2022, 07:01 AM
  #441
Registered User
tetfemal's Avatar
Originally Posted by _zebra
maybe disregard my pictures in response to your other post... ain't sure on the 03+ fuse block as mine was a 99-02, which had a different harness & computer.
i'd still say it's worth asking your dealer service guys to pull out the electrical diagram & verify by the last 8 of your VIN which holes of the fuse block have your clutch safety switch wire.
found this online. The v6 is still in the truck so, The wire from the pcm should still be there. I’m guessing I just need to run a wire from the clutch safety switch to the white firewall fuse block connector
Old 09-12-2022, 12:20 PM
  #442
makes children cry
_zebra's Avatar
shouldn't be no need to run lines... it literally just goes from one hole to the next in the bottom side of the engine harness fuse block.
Old 09-12-2022, 04:09 PM
  #443
Registered User
tetfemal's Avatar
yeah I found those pictures of yours two nights ago and went out to check and I’m pretty sure there was a green/white wire in F11. I could’ve been reading it wrong but I’ll check again when I get back into town
Old 09-15-2022, 01:03 AM
  #444
jesusv59's Avatar
Default Fuse box
Do u guys know if i could use my v6 fuse box or do i need the v8 fuse box?
Old 09-15-2022, 07:25 AM
  #445
Registered User
tetfemal's Avatar
not sure but I do know there are some differences between 99-02 & 03-07 fuse blocks
Old 09-15-2022, 10:02 PM
  #446
makes children cry
_zebra's Avatar
installing an engine/harness for a 2001 into my 99, i only had to swap the black engine-harness section of the fuse block; the rest stayed.
crossing configuration boundaries from early-NBS to late-NBS, i couldn't tell you for sure.
Old 09-15-2022, 10:14 PM
  #447
Registered User
tetfemal's Avatar
Right. I did the opposite. The v6 stayed in but swapped out the dash harness
Old 09-17-2022, 01:52 PM
  #448
jesusv59's Avatar
Default Fiel line issues
Hello im currenty looking for my fuel line parts, question is with the fuel line, what so u mean with female end do u have any other part numbers ? Tia
Old 09-17-2022, 04:01 PM
  #449
100% Redneck
RedXray's Avatar
Received 1,334 Likes on 794 Posts
Do you mean the unions connecting the braided stainless lines?
The part numbers for all the fuel lines and connectors are at the beginning of this thread.
This was a test fit for length to mark the hard fuel lines for the cut.
Or these?
Old 09-17-2022, 05:54 PM
  #450
jesusv59's Avatar
Or these?
yea those so i have to cut the lines on the intake side or the ones that go to the tank?
Quick Reply: Official NBS V6 to GENIII V8 swap Guide
