Official NBS V6 to GENIII V8 swap Guide
#441
maybe disregard my pictures in response to your other post... ain't sure on the 03+ fuse block as mine was a 99-02, which had a different harness & computer.
i'd still say it's worth asking your dealer service guys to pull out the electrical diagram & verify by the last 8 of your VIN which holes of the fuse block have your clutch safety switch wire.
found this online. The v6 is still in the truck so, The wire from the pcm should still be there. I’m guessing I just need to run a wire from the clutch safety switch to the white firewall fuse block connector
#443
yeah I found those pictures of yours two nights ago and went out to check and I’m pretty sure there was a green/white wire in F11. I could’ve been reading it wrong but I’ll check again when I get back into town
#445
#447
Right. I did the opposite. The v6 stayed in but swapped out the dash harness
#449
100% Redneck
#450
yea those so i have to cut the lines on the intake side or the ones that go to the tank?
