Oh my, I think I've made a mistake >.>
Old 08-13-2010, 09:27 AM
meangreenburban's Avatar
Default Oh my, I think I've made a mistake >.>
I've been lurking around cam threads for a while and think I may have screwed up. I have a Comp 218/224 and 918 beehives in my Vortec 5700 L31. I uh. . .I also have STOCK push rods. I know, it's a bad idea, that I've just recently realized
So 2 questions, what's a good brand/type of push rod to go with and,
What is my standard push rod length?
I wanna get this thing dialed in and running right
edit: The heads are stock height, no milling.
Old 08-13-2010, 09:38 AM
13 Second Truck Club
LS1FREEK's Avatar
I have Comp chromoly pushrods. Stock length is 7.400 inch. You can get them over at Texas Speed (www.texas-speed.com)
Old 08-13-2010, 09:44 AM
7.4 for SBC and LSX both?
Old 08-13-2010, 09:51 AM
Wearin' da big hat
00ChevyScott's Avatar
No, he just didn't read closely.
Looks like standard length is 7.187", is the base circle the same as stock on that cam?
Old 08-13-2010, 09:59 AM
yessir it is
so am I looking for a 7.1 push rod?
I wish I had done as much research on push rods as I did on springs and cams and all the other valve train stuff, now I just feel dumb lol
Old 08-13-2010, 10:49 AM
dlt76028's Avatar
I'm on stock push rods right now, my friend also is running them. It's not super important IMO.
Old 08-13-2010, 11:10 AM
LS1FREEK's Avatar
Thanks Scott! You're right, i read it too fast. I need a bigger screen on my phone LOL.
Old 08-13-2010, 11:38 AM
Wearin' da big hat
No prob. SBC stuff is rare on here so it's easy to overlook it.
Old 08-13-2010, 11:43 AM
1dirtybird's Avatar
Did you pull the heads? On vortec heads you have to cut the guides to have anything over .460 lift. Also your press-in studs arnt going to like the pressure from those 918's. You dont have to cut the seats for the 918's but you will kill your seals in no time at all.
As for push rods stockers will work fine as long as you are not using guide plates. A cheap fix are 92-95 stock LT1 push rods as they are hardened.
and those vortecs will like that cc502, pulls hard down low to 6 or so
Old 08-13-2010, 11:44 AM
Camaro Zach's Avatar
On LS based stuff its not so important with low lift and relatively low rpm stuff. But for what it's worth I have seen more than a handfull of completely factory F-bodies with bent pushrods.
But Gen1 SBC stuff is totally different. In many cases the pushrods actually contact the head which puts added pressure on the pushrods. The heads actually guide the pushrod and help to hold it in place.
Quick Reply: Oh my, I think I've made a mistake >.>
