Oil Catch Can Noise?
Old 07-28-2005 | 03:25 PM
  #21
redLS1rado's Avatar
Would a regular old truck with no mods benefit from a catch can? Is it worth the $160?
Old 07-28-2005 | 03:30 PM
  #22
therock's Avatar
Default $160.00 ?
I paid $60.00 less direct. I believe every litle bit helps.
Old 07-28-2005 | 03:42 PM
  #23
04BlackGmc's Avatar
10 Second Club
Would a water seperator for a air compressor work good?
Old 07-28-2005 | 04:59 PM
  #24
therock's Avatar
Default Not!
This has been tried before and works for a little bit but the seperator element clogs. It is designed for water.
Old 07-28-2005 | 06:23 PM
  #25
04BlackGmc's Avatar
10 Second Club
how long? anything better i can get if i dont wanna spent 160?
Old 07-28-2005 | 07:18 PM
  #26
budhayes3's Avatar
PT's Slowest Truck
My home made one only went about 2k before it started sucking oil through...didn't even make it to the first oil change. My AMW catch can has been flawless so far.
Old 07-30-2005 | 11:25 AM
  #27
04BlackGmc's Avatar
10 Second Club
http://benelliwang.badassride.com/Engine/index.html#PCV
OK i did this exact sytle one.
Ok i cant get the one i got to quit making noise... hissing..
I'm using the Air/wAter Seperater for now..
Have the hose running from the back of the motor into it with the arrow pointed towards the intake..
Everything is tight..Trust me..
Old 07-30-2005 | 11:39 AM
  #28
budhayes3's Avatar
PT's Slowest Truck
That's the exact same setup I had that sucked oil through...I even used the same write-up. The first few weeks it filled up very quickly, then the level stopped rising
Old 07-30-2005 | 05:00 PM
  #29
04BlackGmc's Avatar
10 Second Club
I know a guy thats been using this for over a year never had a problem, so whats the deal with the noise.
Old 07-30-2005 | 06:07 PM
  #30
budhayes3's Avatar
PT's Slowest Truck
I think the noise has to do with combining the AMW catch can with the new style fixed orifice PCV...it works, but it whistles. Don't think it's a problem, more of a characteristic. When I switched back to the original style spring and plunger PCV, my whistle noise went away. I drain the AMW every oil change, and mid-way between, and I often check the vacuum line from the can to the intake, and so far the line has been dry, so this is the setup I've been using since it's both quiet and works for me.
I tried the homemade setup with the fixed orifice PCV, and unfortunately for me, it was not effective. The reservoir filled up to about a tablespoon or so, then that was it. When I pulled the hose from the seperator to the intake, it was saturated with oil. I guess not all engines will react the same way...different brand oils may have something to do with it also?? (I use Mobil1 10w-30)
