oil cooler???
has any used an ebay oil cooler? can some post pics of their setup looking for ideas i found a couple found little around $100 any ideas also??
right but i had a 4.8 and it didnt have the oil cooler built into the radaitor...the 6.0 came with a oil cooler lines and i just want to have them hooked up the right way....
BECAUSE THE 6.0 COMES WITH IT..my 4.8 didnt have one so i figured if the lines are there that means im suppose have it hooked up.....wont the ebay ones be enough why would i need a thermostat the way it is set up right now it runs to an external oil cooler right in front of the radiator the guy who did my swap installed it all i want is just better lines...because the ones i have now are leaking and cracked..
