oil pan gasket question
Old 10-08-2009, 02:02 PM
Irby's Avatar
Default oil pan gasket question
on an 04 lq4 the oil pan gasket is rivited to the pan when i change the gasket do i have to rivit the new one to the pan
Old 10-08-2009, 07:40 PM
Grumpy5.3's Avatar
you could if you want too, but you dont have too. I just put the gasket on and start a couple bolts into the rubber insert of the gasket to hold it still
Old 10-11-2009, 08:03 PM
eallanboggs's Avatar
There is an elaborate alignment procedure for the GenIII LS pan/timing cover. Don't forget to put a dab of RTV at the Pan/Block/Timing Cover junction when putting the cover back on.
Old 10-11-2009, 08:16 PM
Baltimore Whore
Mangled03gmc's Avatar
No you dont need to..
USMCvet0311
08-01-2015 07:45 AM
Ls3silverado
07-31-2015 04:22 PM
05SilveradoSS
07-29-2015 08:34 PM
jmarkway
07-18-2015 09:23 PM
Quick Reply: oil pan gasket question
