Oil pressure goes up when accelerating...Y???
06 SSS... ok so this started happening after i installed my LT's, the pressure goes up when i accelerate it but it stay level at idle. has anyone else ever experienced this or know what maybe causing it???
-Rob
-Rob
Your oil pressure will rise as the RPMs rise, the more the engine turns the more the oil pump pushes through more oil.(causing a rise in pressure) It's normal.
Now you may have added too much oil your last change causing too much oil pressure but you didn't say you had an issue after an oil change though.
Originally Posted by trever1t
Uh, it's supposed to increase with higher revolutions.
As said, that is very normal, nothing to worry about.
... and car enthusiasts wonder why newer vehicles have dummy gauges. Like some GM cars and their water temp gauge that reads 210 when warmed up, no matter if it is 180-230 degrees.
Cool thnx guys really appreciate the replys, im glad it is normal, as for the oil change i dont think i put too much (5Qt's), let me know if it was too much.
P.S. hey 12secSS would have been great to have u out at the G2G this sunday there was about 17 of us out there, check out the pics at the Western forum....
Originally Posted by Z06 DREAMING
Damn Trever, you're quick with the replies! I didn't even see your post when I hit reply.
Yeah, it's normal. Should be as high as 60lbs at big throttle and just under 35-40psi at idle.
